rear hatch
whats up guys, need your help... my rear hatch one day stopped working as to say the window wouldnt pop open... i have the one with the button on the tailgate, inside the cab and on the alarm key... i figured the fuse might be blown replaced that, still nothing. i thought maybe the latch motor went just replaced that today, still nothing... does anyone have any ideas? cause im out of them. and im starting to get really fed up of not being able to open my hatch with out climbing through the truck and unlatching it manually
any help would be greatly appreciated tim |
RE: rear hatch
You said you did replace the motor??? Can you hear the motor running when you press the button? If so...I don't know what to tell ya. But heres something just incase.
https://blazerforum.com/m_39183/tm.htm wait...sorry...nm...i re-read the thread...and what i sent will have no help for you...did the plastic clip on the motor break? |
RE: rear hatch
i had the same problem on my 95 and all i did was buy a switch from radio shack and wired it up and it has worked ever since, when i checked to see if i was getting power to the switch i wasnt so i had to tap into my horn through the fuse box to get power and now i havent had a problemsince
RE: rear hatch
i dont hear the motor going... cmiller... do you think you could give me instructions to do that? im not at all good with wiring
RE: rear hatch
It's possible that you have a bad relay in the Body Relay Block located under the LH of the dash, right of the IP Fuse Block.
here's a pic of the liftglass relays. #9 & #10 [IMG]local://upfiles/2910/A8A91438798941A7AE654354A5C11D90.gif[/IMG] |
RE: rear hatch
i meant to say when i originally posted that i changed the relay... but that diagram is dif than the mine... i only have one relay or so it says on my diagram.... but is there a fuse bc i couldnt find one
RE: rear hatch
any other suggestions?
RE: rear hatch
when mine quit workin the bar the moves over to grab the latch to pop it was got bent some how and bent to where it grab and it works now so you ight want to check that.
RE: rear hatch
could be a bad ground maybe?
