General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
rear hatch
Old Oct 13, 2006 | 01:10 PM
timetoblaze's Avatar
timetoblaze is an unknown quantity at this point
Default rear hatch
whats up guys, need your help... my rear hatch one day stopped working as to say the window wouldnt pop open... i have the one with the button on the tailgate, inside the cab and on the alarm key... i figured the fuse might be blown replaced that, still nothing. i thought maybe the latch motor went just replaced that today, still nothing... does anyone have any ideas? cause im out of them. and im starting to get really fed up of not being able to open my hatch with out climbing through the truck and unlatching it manually
any help would be greatly appreciated
tim
Old Oct 13, 2006 | 03:19 PM
magnum434's Avatar
magnum434 is an unknown quantity at this point
Default RE: rear hatch
You said you did replace the motor??? Can you hear the motor running when you press the button? If so...I don't know what to tell ya. But heres something just incase.
https://blazerforum.com/m_39183/tm.htm
wait...sorry...nm...i re-read the thread...and what i sent will have no help for you...did the plastic clip on the motor break?
Old Oct 13, 2006 | 09:33 PM
cmiller86's Avatar
cmiller86 is an unknown quantity at this point
i had the same problem on my 95 and all i did was buy a switch from radio shack and wired it up and it has worked ever since, when i checked to see if i was getting power to the switch i wasnt so i had to tap into my horn through the fuse box to get power and now i havent had a problemsince
Old Oct 15, 2006 | 11:08 PM
i dont hear the motor going... cmiller... do you think you could give me instructions to do that? im not at all good with wiring
Old Oct 16, 2006 | 12:20 AM
Chevy Lover's Avatar
It's possible that you have a bad relay in the Body Relay Block located under the LH of the dash, right of the IP Fuse Block.
here's a pic of the liftglass relays. #9 & #10
[IMG]local://upfiles/2910/A8A91438798941A7AE654354A5C11D90.gif[/IMG]
Old Oct 16, 2006 | 12:54 AM
i meant to say when i originally posted that i changed the relay... but that diagram is dif than the mine... i only have one relay or so it says on my diagram.... but is there a fuse bc i couldnt find one
Old Oct 17, 2006 | 09:00 PM
any other suggestions?
Old Oct 17, 2006 | 09:29 PM
mudsliner's Avatar
mudsliner is an unknown quantity at this point
when mine quit workin the bar the moves over to grab the latch to pop it was got bent some how and bent to where it grab and it works now so you ight want to check that.
Old Oct 17, 2006 | 10:00 PM
93s15jimmy's Avatar
93s15jimmy is an unknown quantity at this point
could be a bad ground maybe?
tmar89
Apr 23, 2013 10:23 AM
Wexinlo
Jun 8, 2012 02:46 PM
1baggedblaze
Apr 13, 2010 04:52 PM
timetoblaze
Dec 14, 2005 10:20 PM
scoot
Feb 24, 2005 09:34 PM
