rear wiper motor replacement
I have the back door apart and on my 99 blazer its a 4 door 4X4 with power locks and remote , I have some very vague removel instuctions with no pictures, does anybody know where I can get a schematic drawing or a least some good instuctions?
RE: rear washer motor replacement
ummm...what for...the motor is under the hood if its like mine...a 96. it shuold be connected to the resivoure
whoops ! I mean wiper motor
Remove the wiper arm from the shaft
Remove the nut and the spacer from the shaft Remove the interior panel from the vehicle endgate Disconnect the electrical connector from the controller Remove two screws and the wiper motor from the vehicle [IMG]local://upfiles/2910/BCE4D230464D415BAD7C9A2329F865C3.gif[/IMG] |
The drawing doesn't show the black bar over the motor where the power lock is located, unless I remove this bar I can not reach the screws shown, the bar looks like its riveted on or held together with some type of fastener I don't recognize
Sorry, I can't see a black bar in the diagrams and diagrams are all I have. My Blazers are much older. I have a '74, an '85 and an '87.
Is the bar just a brace or are there components attatched to it. Can you see if it's held on with bolts or rivetts? |
they look like black rivets I managed to extract the motor with jointed sockets but there should be an easier way to get at this, upon inspection the plastic gear wheel in the motor is striped and this appears to be fatal. on the upside this will buy me some time to figure out how to get it back together!
| All times are GMT -5. The time now is 05:12 AM. |
