Should the 2WD indicator light be on?
there are two ways to get the switch out, one is to remove two screws above steering wheel in the dash, and then you can pull off that hole section. , or you can just pry out the whole switch assembly pretty easy. disconnect the wiring harness as the back, and then pull the switch all the way out. then there is just a little clip holding the board in.
ORIGINAL: hillbillyinOhio
kthdwn
Nov 7, 2009 11:36 PM
PiTRiFF
Feb 13, 2009 04:31 PM
Daninehnj
Feb 22, 2007 02:26 AM
