General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Should the 2WD indicator light be on?
Old Apr 17, 2006 | 04:28 PM
qbee1776's Avatar
qbee1776 is an unknown quantity at this point
Default Should the 2WD indicator light be on?
Should the 2WD indicator light be on when running in 2 wheel drive? Not Sure, but seems like it should be on when it is in 2 Wheel drive.
Old Apr 17, 2006 | 04:30 PM
hillbillyinOhio's Avatar
Default RE: Should the 2WD indicator light be on?
no, that pos bulb burns out. Just make sure that it is in 2wd and not 4wd. Mine is the same way
Old Apr 18, 2006 | 01:15 AM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
The bulb should be on in 2wd. my bulb burned out too a while back, its cheap and easy to replace.
Old Apr 18, 2006 | 05:47 PM
Whittaker's Avatar
Whittaker is an unknown quantity at this point
It's easy to replace ?
Do tell.
My 4WD HI and 4WD LO lights both flash and stay on, but the 2WD light is dead. I didn't see an easy way to get at, but I only gave it a once over.
Old Apr 18, 2006 | 05:52 PM
there are two ways to get the switch out, one is to remove two screws above steering wheel in the dash, and then you can pull off that hole section. , or you can just pry out the whole switch assembly pretty easy. disconnect the wiring harness as the back, and then pull the switch all the way out. then there is just a little clip holding the board in.
Old Apr 19, 2006 | 01:22 AM
KA3AX's Avatar
KA3AX is an unknown quantity at this point
Thanks guys, I needed that info too!
Old Apr 19, 2006 | 06:10 PM
Whittaker's Avatar
ORIGINAL: hillbillyinOhio
I considered that, but I worried that something might snap off that is retaining it from the backside. So just to confirm, there's nothing holding it in and the whole assembly can come straight out the front ?
Old Apr 19, 2006 | 06:13 PM
no, there is nothing holding it in
Old Apr 19, 2006 | 06:16 PM
Whittaker's Avatar
Great.
Thanks
Marcin
Oct 27, 2013 08:02 AM
dolphin1
Nov 8, 2009 07:24 PM
kthdwn
Nov 7, 2009 11:36 PM
PiTRiFF
Feb 13, 2009 04:31 PM
Daninehnj
Feb 22, 2007 02:26 AM
