General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Starting Problems
Old Oct 20, 2006 | 01:39 PM
z28chic's Avatar
z28chic is an unknown quantity at this point
Default Starting Problems
I have a 1996 4x4 blazer. When I try to start it, it just turns & turns & it will get a spurt where is sounds like it's going to turn over & then it don't, it just goes back to turning. If I keep spraying starting fluid in it, it will eventually start & once it's started it runs like a champ, until I turn it off again. Any ideas?
Old Oct 20, 2006 | 01:42 PM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
Default RE: Starting Problems
this may sound low end, but maybe check the spark plugs and wires. also - is anything possibly clogging the air intake a little?
Old Oct 20, 2006 | 01:53 PM
z28chic's Avatar
I will def. check. I am gonna put the battery charger on it here in a little bit & get a video of it trying to start, do you think that will help diagnose?
Old Oct 20, 2006 | 02:06 PM
maybe - it would at least clearify any questions people might have about whats going on.
Old Oct 20, 2006 | 02:09 PM
Yeah, if you don't know when the plugs/wires/cap/rotor were last changed, that is definitely a good place to start. Also, while you are at it, swap in a fresh fuel filter.
cgrett
Nov 15, 2010 09:08 PM
upblazer95
Apr 4, 2009 08:27 PM
Sprocket
Mar 20, 2008 09:39 PM
Dean S
Jan 30, 2006 02:51 AM
smplgrn
13
Jan 23, 2006 09:02 PM
