General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
steering wheel
Old Jul 19, 2006 | 10:39 PM
Black95's Avatar
Black95 is an unknown quantity at this point
Default steering wheel
i need to take the wheel off my truck to get at a screw to take the switch out for my cruise lever. my question is when removing th wheel do i just pull the center peice out of the wheel? i have an airbag am i going to mess it up or something if i pop it out to take the wheel off? i am used to gt steering wheels with a center cap that comes out and some bolts inside for removing the wheel. any help would be appreciated in getting this thing off without messin it up
Old Jul 20, 2006 | 12:06 AM
Chevy Lover's Avatar
Default RE: steering wheel
I have no idea what your truck is. Make, model, year would really be a good thing to post when you need advice.
Old Jul 20, 2006 | 12:20 AM
Black95's Avatar
good point, i am just used to people knowing what i drive from other sites. its a 95 4wd 4dr cpi blazer, auto w/ cruise. enough info?
Old Jul 20, 2006 | 03:31 AM
This info is for a '99, your '95 might not be exacly the same, but it's probably similar.
Make sure you pull the SIR fuse. Then remove the trim panel (knee bolster) to access the lower part of the steering column.
Disconnect the yellow 2 way connector.
To remove the airbag module ( the center pad of the steering wheel) there should be 2 access holes in the back of the steering wheel.
(you probably have to turn on the key and turn the steering wheel one way and then the other to get to the holes. (Don't turn the steering wheel all the way around... just one way and then the other). Use a small flat blade screwdriver to release the plastic tabs to remove the airbag module.
Go easy when you remove it, there's an electrical connector inside that needs to be disconnected.
Hope this works for your '95
Old Jul 20, 2006 | 08:19 AM
I can't look right now, but are you sure you have to remove the steering wheel to change out the multifunction switch? When I get home from work, I'll look it up, but right now I can't remember exactly what the steering column in a '95 looks like.
Old Jul 20, 2006 | 07:04 PM
Black95's Avatar
yes i am looking at it and there is one screw in particular that looks like can not be taken out without removing the wheel. you might be able to with a special socket but i just dont have one that can get that kind of angle
ctyler
Aug 25, 2020 04:06 PM
litterbug
Oct 19, 2011 07:50 AM
Parilio
Sep 21, 2011 06:56 AM
caseroj
Oct 20, 2010 08:10 AM
pilgrim
Apr 3, 2006 03:57 PM
