General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
temp gauge going back and forth
Old Nov 5, 2006 | 12:59 AM
98blazergal's Avatar
98blazergal is an unknown quantity at this point
Default temp gauge going back and forth
Well, my 98 blazer's temp. gauge goes from normal (Halfway) to hot or 3/4 way on the gauge. It will stay there for a few seconds then go back down. I just had a new heater core put into it. Could it be that? When it goes back down sometimes my heater starts blowing harder. So far it has never went into the red, but I know it shouldn't be fluctuating back and forth like this. Does anyone have any suggestions for me? Thanks a million if you do!
Old Nov 5, 2006 | 01:06 AM
Chevy Lover's Avatar
Default RE: temp gauge going back and forth
You might have an airlock in the cooling system. Check the radiator level, when it's cool, to see if it's low now. If your problem continues, I recommend changing the thermostat.
Old Nov 5, 2006 | 01:48 AM
Thanks a bunch for youre reply. It is greatly appreciated!!! I'll leave a comment whether it works or not! Thanks again!!
Old Nov 5, 2006 | 01:49 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
ORIGINAL: Chevy Lover
solid advice
w/ engine cold remove the radiator cap start truck let it warm up to ensure all air pockets are released and let it run awhile like this
shut truck down let it cool and check your lvl in the radiator (top off if need be
replace cap, start and test again.
if same happens then replace your thermostat
(or just replace thermostat and refill system and purge it)
I have found that when the heater cores are faulty and need replacement, normally suggest the thermostat also. Most people dont replace these avg 5 yr life span. Coolent 2 yr avg. (Dexcool never use and remove asap if already equipt in system)
er0ck273
Sep 1, 2013 11:45 AM
zakm0n
Jan 9, 2011 07:31 PM
jmaynard
Aug 28, 2010 03:56 PM
soundguy
Sep 20, 2007 03:23 PM
beilharzc
Mar 12, 2006 01:50 AM
