General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Transmission fluid loss
Old Mar 12, 2006 | 12:54 AM
4lowlife's Avatar
Default RE: Transmission fluid loss
Blow out all the atf fluid the best you can.
Old Mar 12, 2006 | 01:31 AM
medion42's Avatar
medion42 is an unknown quantity at this point
OK I will try to do that . Do you know the fuction of the vacume switch? Thanks Dan
Old Mar 12, 2006 | 01:32 AM
4lowlife's Avatar
I think activates when you switch out of 2 hi.
Old Mar 13, 2006 | 12:00 PM
Hanr3's Avatar
You need to replace the input seal on the t-case, not the output seal on teh tranny. There is a void where the adapter connects the t-case to the tranny, if the output on the tranny is leaking it will fill up that adapter, and that is no big deal, in fact you need some tranny fluid in there to lubricate the governor. However you need to fix the input seal on teh t-case, otherwise the t-case will get overfull of tranny fluid. Most GM t-cases take ATF.
The vacuum switch controls your 4wdr system, specifically your vacuum activator located on the passengers side fender below the battery. There are three hoses, one hose provides vacuum to the system, one hose provides vacuum to the vacuum modulator under the battery, and the 3rd hose is a vent hose.
You MUST clean out all the fluid in the hoses. Not only does the fluid plug up teh vacuum system for the 4wdr, it is also connected to your heat-a/c vacuum controls. If you have too much fluid it will get into the heat-a/c controls and you will replace them to fix the problem.
Fortunately, you may have caught the problem before it affected your heat-a/c system.
Old Mar 16, 2006 | 10:18 PM
medion42's Avatar
Thanks fellows I think we our back in business and it all seem to be working at the moment. Dan
quinnsjoblom
Apr 9, 2014 08:32 AM
Mr Mackey
Jun 28, 2013 07:13 PM
bryanmine
May 19, 2011 11:27 AM
964x4ND
Mar 4, 2009 09:20 PM
Major Pain
Jan 19, 2007 04:36 AM
