General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
what is the best transmission cooler..
Old Nov 21, 2005 | 10:24 PM
ivannj's Avatar
ivannj is an unknown quantity at this point
Default what is the best transmission cooler..
I looking to buy a transmission cooler and would like some of your feedback. Which one do you think is the best.
Old Nov 21, 2005 | 11:02 PM
89Blazze's Avatar
89Blazze is an unknown quantity at this point
Default RE: what is the best transmission cooler..
B & M is my choice works great for my other vehicals also.
Old Nov 21, 2005 | 11:38 PM
Hayden is the off-branded B&M for cheaper. A stacked plate design is more rugged than the tube with fins and it is only slightly less efficient.
Old Nov 21, 2005 | 11:49 PM
Ok... This is the fitting kit that you need:
AutoZone - Hayden fitting kit - 240390
Advanced Auto - Imperial/Hayden Fitting Kit - 240390
I'm not sure if it's available from other stores. I bought that and the Hayden Imperial Maxi-Cool 7-3/4"x11"x3/4"thick stacked plate cooler - Hayden Maxi-Cool XL - 243007.
I bought it from Advanced Auto, but they did not carry the fitting kit. Here's the link to advanced auto's website - Advanced Auto - Hayden Maxi-Cool XL - 243007
Old Nov 22, 2005 | 01:00 AM
ivannj's Avatar
I just bought the:
Brand: FLEX-A-LITE
Description: 20,000 GVW, Heavy Duty 6-Pass Rail Cooler - 3/8-inch ****** Fitting
Will I need anything else with this. Check it out @ truckperformance.com. This is where I orded it from. I hope to get them by saturday to install them by sunday.
Old Nov 22, 2005 | 08:10 AM
Good luck finding a place to mount that thing... I went with a 7-1/2"x11" for a reason... There wasn't enough room for hoses and the cooler in front of the radiator. The 7-1/2"x11" was just the right size. Also, you can have too much cooling. If you aren't towing frequently and/or living in the mountains, that GVW rating is way too high.
This is exactly what I've got even though I purchased it locally and under a non-brand name, B&M SuperCooler 7-1/2"x11"x3/4" Stacked Plate Cooler.
Oh and I would bet that you would still need the fitting kit unless you wanted to cut your transmission lines like the instructions suggest.
Old Nov 22, 2005 | 03:28 PM
Hanr3's Avatar
I like the stacked plate design myself. I also don't mind cutting the factory line to connect the rubber hoses. Use a pipe cutter instead of a hacksaw though. A hacksaw will leave little metal filings in the line, while a pipe cutter leaves clean ends.
Old Nov 22, 2005 | 03:38 PM
Its not that I mind cutting a factory line, but I'd rather be able to cleanly undo any modification that I do to a vehicle. Definitely use a pipe cutter to cut the line!
Old Nov 23, 2005 | 01:43 AM
Hanr3's Avatar
ORIGINAL: swartlkk
Hahahaha, I never return them to original condition. I drive em till they die or the wife makes me trade it in. She has this image thing to maintian. Me, I could care less what it looks like, as long as it is mechanically sound.
Old Nov 23, 2005 | 07:58 AM
Very true. I'd like to drive 'em until they die, but many times it's the little annoyances that finally get to me and force me to get rid of it. Electrical gremlins are the worst and hardest thing to figure out. That's the primary reason why I got rid of my old '94 Intrepid. I loved the car, but it was starting to degrade (electrically) and while the car still looked good, I dumped it!
