Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Benefits of cold air intake
Old Feb 25, 2011 | 05:33 PM
  #31
markjr390's Avatar
markjr390 is on a distinguished road
Originally Posted by Longer02
Huh? There is no "chip" for his Blazer's PCM. You can send the PCM off to PCMforless and get it tuned for $175. Cheaper and yields more gains than a CAI.
Nice thread bump BTW.
Lol not my intent to bump, without getting way off topic... I was going to rip my ECU,pcm, apart out of one of my Blazers and see but from what i have read and understand about the engine computers is they contain a eprom chip that stores values for all the information available and based on the information the sensors are giving and produces a pacific result. Its static information and can not be altered. The only way to change it is to flash it (which you risk destroying the ecu,pcm) or to take the ECU,pcm apart replacing the chip(eprom) inside the ecu,pcm. The information stored on there is in Hex and if you buy a programmer and emulator you can change the values indefinitely without a set limit. The hardest part is knowing Hexadecimal language and figuring out the values in the table. Would like to know the different systems between 95 and 01. but not relevant to this thread. anyone tried a forced air intake?
Old Feb 25, 2011 | 05:40 PM
  #32
If you are working with an OBD2 PCM, you will destroy it if you attempt to take it apart. It can be reprogrammed with the proper software (HP Tuners, EFI Live, etc) which is what tuner shops use which does not require any disassembly of the PCM.
The older ECUs used in the TBI motors had a removable EPROM chip, but that went away with the advent of flashable (rewritable) chips.
Old Apr 29, 2011 | 07:11 PM
  #33
TMM217's Avatar
TMM217 is on a distinguished road
Default Why called a CAI
Does using a CAI lower the IAT cause Im using a Spectre CAI and the IAT sensor was reading bout 10 degrees higher than OAT while driving on freeway @ 70mph. Is this normal when using a CAI or is OEM airbox create warmer than 10 degrees in this case. Feel like IAT should be close to OAT
Old Apr 29, 2011 | 11:33 PM
  #34
TMM217's Avatar
Do cold air intakes really work by cooler air charge?
Old Apr 30, 2011 | 12:07 AM
  #35
Thogert's Avatar
I've got a question for ya, the PO of my blazer put a cone specter filter on the end of the stock intake tube. what do you think I should do? Buy an aftermarket tube or go to a junkyard and get a stock airbox.
Old May 2, 2011 | 10:00 AM
  #36
TMM217's Avatar
How is a CAI beneficiary? What does it really do?
ravenhurst
15
Apr 26, 2009 07:53 AM
dimmuborgir6nik6
Oct 2, 2008 06:51 AM
BlaZeR FXB1581
Jan 26, 2006 08:11 PM
il67bp
Aug 16, 2005 01:33 PM
Long Live #3
Feb 15, 2005 11:41 PM
