Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Catalytic Converter Problem
Old Oct 5, 2010 | 01:59 PM
m5james's Avatar
m5james is an unknown quantity at this point
Originally Posted by R2P
I took it to the exhaust shop yesterday, it was a bad cat. Turns out Advance Auto Parts gave me the wrong cat (that makes two they've given me that were wrong). I also have cat pieces in my muffler from the first one that went out so I'll be looking at mufflers soon. Flowmaster 50 series any good?
Do you remember which versions they gave you first and what they gave you the second time? I don't know how hugely different your 98 is vs my 90 in regards to what cats can be used, but from what I found out and posted here https://blazerforum.com/forum/headers-intake-exhaust-10/hi-flo-cat-worth-48153/ is that the 94000 series is for the 4.3's while the 91000 series is for the 2.8's. I'm guessing they gave you the smaller 91000 series since you said they gave you the wrong one and it failed so quickly. Can you confirm this?
Old Oct 5, 2010 | 04:10 PM
R2P's Avatar
R2P
R2P is on a distinguished road
I dont know what the bad one was. Is the series stamped on the cat itself anywhere? I'll crawl under there and hope its on the side facing down if it is. Otherwise, I don't have any of the paperwork anymore.
I can tell you they were roughly the same size but I do believe the one that didnt fail had a slightly larger inlet/outlet.
Old Oct 6, 2010 | 08:55 PM
88Vic's Avatar
88Vic is on a distinguished road
Originally Posted by m5james
But both the vehicles in your signature are V8's, while the OP owns a little 4.3L V6. What works for your engines may not work for ours.
Both mine are gen 1 small blocks, same as yours plus two cylinders, only difference will be sound, it'll perform like it does on mine, which is very well.
Old Oct 17, 2010 | 01:49 PM
R2P's Avatar
R2P
Well on the cat it says 93304, which turns up direct fit ones when googling, although it's a universal. I'm guessing its the same cat as on the direct fit ones, just without the direct fittage.
Old Oct 17, 2010 | 01:58 PM
m5james's Avatar
Interesting. Thanks for letting me know.
dano440
Oct 30, 2012 08:22 AM
dillonml
May 24, 2008 12:15 AM
sgtbrum
Dec 18, 2006 11:29 AM
88redk5
Oct 26, 2006 06:24 AM
Mbastet99
Aug 25, 2006 09:34 PM
