Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Cold air intake(oh no not again!)
Old Jan 30, 2008 | 09:31 PM
rastaskater's Avatar
rastaskater is an unknown quantity at this point
Default Cold air intake(oh no not again!)
Ebay! I figure a cold air intake is a cold air intake. Check this out.
eBay Intake
All it needs is an heatshield.....
anyone have any expeirence with these? Opinions?
Old Jan 30, 2008 | 09:55 PM
SilverTalon's Avatar
SilverTalon is an unknown quantity at this point
Default RE: Cold air intake(oh no not again!)
I purchased one for my '94 and have a regular AEM cone filter on it. Got the filter from Advanced for about $15 and it's working great. I didn't have my Blazer long before I got it, I got my Blazer with a broken OEM filter box.
I had to make a way to support the filter end of the tube, but that was pretty simple. Alternator clearance is TIGHT so when you make your support, don't forget to figure that into it. The crack case vent tube was interesting. I had to cut a 4inch piece of the hard tubing and put it in the end so that it would go into the gromet they supply with it.
I also noticed (with mine at least) that the tube was a BIT small to properly accept a normal aftermarket filter, so I took the blue piece that goes between the tube and the intake, cut a 1" wide piece out of it, and placed it on the other end as a spacer to get the AEM filter to seal properly and tightly on the end.
As for a heat shield, I'm sure some fiberglass and time would allow someone to make one without an issue. There's MORE than enough room in that corner after you get the stock air box out of there.
Old Jan 30, 2008 | 10:02 PM
Okay. Yeah i heard it can rub against the alternator. What do i do to stop that? Keep in mind, i dont have TONS of tools to do crazy stuff. Just the basics.
Thanks.
Old Jan 30, 2008 | 11:05 PM
94blueknight's Avatar
94blueknight is on a distinguished road
i would say make a braket to raise it a lil bit above. i've also been very curious as how these cheap ebay intakes hold up and work. i was thinkin of buyin one and painting it w/ some heat resistant paint to help it and build my custom heat shield (theres a thread on here on how to build ur own custom cai just search for it using the search tool) its really good info even tho it is for a 2nd gen blazer the concept is still the same
Old Feb 6, 2008 | 12:41 PM
mccague36's Avatar
mccague36 is an unknown quantity at this point
I have ebay bought cold air kits on my '98 blazer and '01 civic, the civic has had the kit installed on it for a good 3 years now with no problems and I just installed the blazers kit a few months ago. So far i cant complain about either. Just make sure you are getting exactly what you need, make sure it will fit. For the most part, if it looks like it will work, it probably will.
Old Feb 25, 2008 | 09:44 PM
Johnkoch's Avatar
Johnkoch is an unknown quantity at this point
Mine has had one on it for a little over a year now and it works good.
Old Feb 26, 2008 | 02:30 AM
thegr81's Avatar
All I did was take my factory air box out and throw on a cone filter from autozone and thats it!!
Old Feb 26, 2008 | 11:21 PM
So i think im going to get the one of ebay. but i dont know about a heat shield.....
Old Feb 27, 2008 | 12:26 AM
fab one up heres a link to a how to for the heat shield and intake
Old Feb 27, 2008 | 05:08 AM
drperry's Avatar
Ebay intake + quality air filter isn't a bad idea...
I just dropped an AEM panel filter into my truck, lol.
