Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Exhaust Manifold Bolt Missing
Old May 21, 2016 | 10:33 AM
Fossil Rock's Avatar
Fossil Rock is an unknown quantity at this point
Default Exhaust Manifold Bolt Missing
I got a O2 sensor error (on the right side). I bought a pair of AC Delco replacements (just in case the other flaked out). Went to replace the one with the code this morning and found the manifold on that side is missing a bolt.
How likely is that to be the cause of the P code and will replacing that bolt correct the O2 sensor error ?
Old May 21, 2016 | 10:40 AM
newguy's Avatar
not likely. Do you have an exhaust leak there? you should replace it anyway
Old May 21, 2016 | 11:13 AM
Other than it running a little rough I can't tell. The typical 'ticking' sound with an exhaust leak doesn't appear to be there, but then again it could be open enough that sound isn't obvious.
I'm gonna find a replacement bolt and get that taken care of too.
Old May 21, 2016 | 12:16 PM
newguy's Avatar
May not be leaking, but will sooner or later. Good idea to fix it
Cheap also
Old May 22, 2016 | 09:31 PM
Any exhaust leaks that are upstream of an oxygen sensor, will cause the sensor to report a lean condition. The PCM will richen the fuel mixture, and your fuel mileage goes right down the toilet. One of the first things that an oxygen sensor DTC flow chart will instruct, is to check for exhaust leaks.
Old May 23, 2016 | 04:29 AM
silverside's Avatar
silverside is on a distinguished road
Good thing you found it out a bolt is missing, surely gonna do a mess soon.
er0ck273
Jun 10, 2014 07:41 PM
justblazin1
Apr 3, 2013 07:31 PM
betsy91s10
Nov 4, 2011 11:10 PM
flfrosty
Aug 10, 2011 01:24 PM
stevie59
Jan 8, 2011 01:45 PM
