Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
? on exhaust systems...
Old Aug 22, 2004 | 02:28 AM
einstein2nd's Avatar
einstein2nd is an unknown quantity at this point
Default ? on exhaust systems...
I have a K&N cool air intake system and a chip in my '01 chevy s10 blazer 2wd 2dr. I would like to install some headers and a cat-back system. But I don't know the brand I should use for the headers. I am thinking of using a flowmaster muffler over the gibson muffler but I don't know what size I should use. Should I use the 3 inch exhaust system or the 2 1/2 inch system?
Old Aug 22, 2004 | 05:02 AM
01xtreme's Avatar
01xtreme is an unknown quantity at this point
Default RE: ? on exhaust systems...
sounds like you have the same questiont at I have. I kinda want a full high flow exhaust system with a high flow cat with a 2.5 or 3" diameter BUT I think that I might just go with a high flow cat and a cat back system and leave the headers and downpipe alone for now...I'm still deciding. I can only find cat-backs for the ZR2 or 4x4's or 4 doors but no luck with the 2 door 2WD. If you find anything, let me know.
Old Oct 16, 2004 | 02:41 PM
2001Blazer4x4's Avatar
2001Blazer4x4 is an unknown quantity at this point
i have a 2001 2 door 4x4, who makes a cat back exhaust for my car?????
Old Oct 16, 2004 | 09:11 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
don't waste your money on a high flow cat...you already have one. the only restrictive cats are the old bead-filled style. the one you have (honeycomb style) is all the aftermarket "high flows" are. the only real restriction in your exhaust is the manifold and the muffler. so i'd just go for the cat-back if i were you. just tryin to help a brotha out!
Old Oct 16, 2004 | 09:14 PM
01xtreme's Avatar
thanks for the info...saving money is ALWAYS a good thing.
Old Oct 16, 2004 | 09:30 PM
zero psi's Avatar
Retired Admin
no problem, i noticed the "empty wallet" in your sig, so i thought i'd help put some back in.
Old Oct 16, 2004 | 09:40 PM
01xtreme's Avatar
every bit helps
Old Oct 18, 2004 | 11:33 PM
timetoblaze's Avatar
timetoblaze is an unknown quantity at this point
2001blazer4x4 i have a 4x4 2dr and the only cat back i could frond was jba its sounds pretty good
its a 3" ......
LucasMI
Mar 23, 2012 10:41 PM
BDS_237
39
Jun 29, 2010 08:07 PM
Sturg
Jan 7, 2010 11:49 AM
strongboy2005
Engine & Internal
Feb 9, 2006 06:12 PM
the_mind
Oct 24, 2005 09:45 PM
