flowmaster 40 series on 4.3??
My friend has one in his 96 jimmy, not super noticeable at an idle. slightly above stock noise. Its once you start revving around 3000-4000 rpms that it seems to wrap a lot and is pretty loud, sounds really good. As for interior noise, it has a drone. Its not too loud, and if you are playing music you wouldnt even notice. You get accustomed to it after a day or two.
I have a 99 s10 blazer , it is rotating and then it acts like it will start then blows exhaust smoke through the throttle body, I have replaced the fuse box numbers matched, had the ecm program and flashed to the vehicle and put a new crankshaft position sensor on and still will not start I need help
I get some cabin noise with my 40 series but not bad. It sounds really good with the 40 series i think, i have a high flow cat also but that doesn't make a big difference. I also have 3" pipe from the cat back which does make all the difference... If you leave the stock pipe in there it sounds a lot higher pitched and raspy. IMO not good... 3" pipe makes a lot deeper sound.
i have a 99 chevy s 10 blazer 4 wheel drive ,the vehicle will not start, it will rotate but will not fire over, i have replaced the fuel pump, fuse box, and new ecm program and flashed to the vehicle, it will act like it is back firing and i get exhaust smoke through the throotle body ,i need help
Instead make a thread here: 2nd Gen S-series (1995-2005) Tech - Blazer Forum - Chevy Blazer Forums With thread tools under the page numbers on the top right of the page
dimmuborgir6nik6
Dec 29, 2007 12:24 PM
new03blazer
Headers, Intake, & Exhaust
Nov 2, 2006 09:43 PM
