Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Flowmaster muffler
Old Dec 2, 2007 | 01:24 PM
RCarp48's Avatar
RCarp48 is an unknown quantity at this point
Default Flowmaster muffler
So I have a 200 Trailblazer with 145000 miles. I got a flowmaster 40 series put on about a 3 months ago and all of the sudden my gas milage was gettin robber and thenI ended up cracking my engine block/blown headgasket, one of the twoI guess. So i had to get my engine replaced and i had a mechanic tell me there is probably no back pressure in it. So i was wondering if i should replace it with the stock or is this not even a problem?? Because if it is i would like to change it up so i can save my new engine.
Old Dec 2, 2007 | 02:43 PM
Idriveachevy's Avatar
Idriveachevy is an unknown quantity at this point
Default RE: Flowmaster muffler
I always thought that less backpressure is a good thing and improves performance..
Old Dec 2, 2007 | 04:54 PM
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
was it running leaner or richer? because usually, well i thought, that you want less back pressure.
Old Dec 2, 2007 | 05:11 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Less back pressure is good in certain applications. Our trucks are sensitive to the amount of back pressure in the system. I am not sure if your particular application caused this or that your engine is just old and was going to need replacing. I would look at the exhaust question pages and see what size pipe and mufflers people are running. My guess is you have too large of pipe if you upgraded that. Otherwise if you just switched mufflers you should be fine. I hope someone else can help you out too.
Old Dec 2, 2007 | 07:38 PM
rriddle3's Avatar
No, the muffler had nothing to do with your previous engine's failure. If your mechanic couldn't tell you whether it was a cracked block or blown gasket, you might seriously consider switching mechanics. When you installed the Flowmaster, if you kept the stock diameter (2.25") pipes, or even went up to a 2.5" diameter, your should not have to worry about exhaust scavenging (what most people are referring to by 'backpressue'.)
Old Dec 2, 2007 | 09:44 PM
Mr Blazer LT's Avatar
Mr Blazer LT is an unknown quantity at this point
ORIGINAL: RCarp48
Ithink it is much better to say you want to have "the right" amount of backpressure instead of less backpressure. You definitely don't wanna go too low on backpressure or it will hurt performance, if anything. Never heard of it causing an engineto blow. Even if it is possible, wouldn't the odds be like in the millions?
I also agree with rriddle3on that mechanic if that is whatyour mechanic really determined.
Old Dec 3, 2007 | 10:40 AM
blazinloud's Avatar
<new muffler and no cat and my engine is fine almost a year later.
Old Dec 3, 2007 | 01:57 PM
RCarp48's Avatar
Gotcha, thanks for all the help. But also How much louder is your blazer with that new muffler and no cat??
Old Dec 3, 2007 | 03:44 PM
blazinloud's Avatar
My bad, i deleted this video.....
Old Dec 3, 2007 | 04:55 PM
TripleBlackBlazer's Avatar
Wow, that exhaust sounds a lot like a roof flexing with a bangin' system in it...
