yea thats what i was thinking getting a slight bigger pipe cut it then clamp it
Hey guys what if i use this ?
Buy Permatex Muffler and Tailpipe Putty 80333/V810 at Advance Auto Parts |
For 6 bucks its worth it. Says its safe for cats.
Originally Posted by ChevyBlazerChick
(Post 455899)
thats what i said LOL whats the worse that can happen ? truck go up on fire ? that already happened but i never wanna go threw that again >.> |
lol, I think the worst that can happen is that it won't patch the leak lol
That stuff will work, but how well it works is dependent upon how well you prep the area. Rough the crack and surrounding area around the entire pipe with some coarse sandpaper, then clean it with acetone or rubbing alcohol. Fill the crack and cover the surrounding area around the pipe with the putty, then tightly wrap the bandage around the pipe. Hold it in place with several pieces of wire. Wet your fingertip and run it around the edges where the bandage meets the pipe to form a bead/seal. Run/Drive the truck for 45 minutes to an hour, then let it sit overnight so the putty/bandage can cure. After that you can remove the wire or leave it on - that's up to you.
I've used these clamps to fix stuff like that and to attatch exhausts because they don't deform the pipe and make removal easy. They work very well (when the proper size is purchased)
Amazon.com: 4" BAND SEAL CLAMP EXHAUST MUFFLER STAINLESS STEEL: Automotive Note: the link is just for reference, obviously you'll have to get the right size, and i have found them locally. |
