Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
K&N or AEM???
Old Feb 13, 2006 | 09:09 PM
strongboy2005's Avatar
strongboy2005 is an unknown quantity at this point
Default RE: K&N or AEM???
Bought the FIPK on ebay (got a good deal)... So i'll be letting you guys know how it goes...
Old Feb 14, 2006 | 09:00 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
if you're worried about heat in the intake tube, DEI makes a heat reflective wrap that will fit over the FIPK tube.
Old Feb 15, 2006 | 03:19 AM
djbass_mekanik's Avatar
djbass_mekanik is an unknown quantity at this point
ORIGINAL: zero psi
i was thinkin of that... but as i said b4, im goin w/ the AEM.. but not till i finish my system, then lowering...
Old Feb 15, 2006 | 10:02 PM
ORIGINAL: zero psi
Is it really that big of an issue? I thought the issue was actually pulling in hot air... I would think that because the cold air only flows through the piping for a split second it shouldn't really heat up...
Old Feb 16, 2006 | 12:56 PM
Bgray's Avatar
Bgray is an unknown quantity at this point
IVe got a FIPK...Works good...gives a sound. Thats about it. Dont expect to get any real results with an intake. Maybe a tiny bit in higher end of the gears(mine did, in my 5 speed blazer). Either would ahve been a good choice, really jsut comes down to preffernce
Old Mar 11, 2006 | 08:03 PM
2klt's Avatar
2klt is an unknown quantity at this point
Instead of a outside wrap or the like, how about a plastic liner for the aluminum with a thin asbestos separator between the two. A bit elaborate I am sure but the heat transfer would be cut way down thinking with my gray matter anyway.... Course there is probably some reason that it would nt be feasible.
anybody have any thoughts on this. It would be easy enough to set up a proto just to see the basics.
Old Mar 17, 2006 | 02:22 AM
2001blazer's Avatar
2001blazer is an unknown quantity at this point
ok so my friend is tryin to make a cold air intake right now everything is made out of some type of metal/aluminum and w/e else but what about makin one out of pvc it would obviously be light and then just throwing a k&n filter on the end i mean im a k&n guy thats y i say that but do u think this would work...hes makin it for his 96 3 series its a 2 dr
Old Mar 17, 2006 | 02:32 AM
4lowlife's Avatar
Fo sho! I have this on my Impala. clickety. After it arrived, I realized someone cut up aluminum, bent it up, and threw a few things in it and marketed it.
I had to purchase a 9" K&n cone seperately.
Old Mar 24, 2006 | 07:25 PM
MitchellIannatto's Avatar
MitchellIannatto is an unknown quantity at this point
What about the gas mileage?
Old Mar 24, 2006 | 11:25 PM
4lowlife's Avatar
18.1 all winter. TB spacer makes the hood bulge upwards.
