Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
mass airflow sensor
Old Nov 13, 2005 | 01:03 PM
BlaZeR FXB1581's Avatar
BlaZeR FXB1581 is an unknown quantity at this point
Default mass airflow sensor
wat does the mass airflow sensor actually do.....is it important?does it need to be ther?
Old Nov 13, 2005 | 01:20 PM
Default RE: mass airflow sensor
It is an integral part of the engine. It tells the engine how much air is coming into the engine. It can not be removed! I believe that MAF sensors are heated element sensors and, by the cooling effect of the air, they produce a voltage drop across the sensing elements. They are ECU (engine control unit) is calibrated to the MAF sensor in its original configuration (ie. with MAF screen and cross-sectional area of the MAF assembly - 2 aluminum peices and the sensor itself). Removing the screen and/or porting the aluminum peices can cause incorrect readings to be sent to the ECU and may cause a lean condition in the engine. It mostlikely will throw a code as well.
Do you have a bad MAF? Or are you just trying to learn? Just wondering what prompted the questions?
Old Nov 13, 2005 | 03:41 PM
idezire
Nov 3, 2011 05:31 PM
abadinalbany
Jun 25, 2009 03:52 PM
ZR 2
Jun 23, 2008 01:57 PM
EuroGoldLS
Mar 25, 2007 01:33 PM
ilikebread
21
Mar 29, 2006 11:30 PM
