Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Proven Solution for exhuast?
Old May 9, 2010 | 11:56 PM
ZR2000's Avatar
ZR2000 is on a distinguished road
Default Proven Solution for exhuast?
ok guys i know this has been talked about alot but bare with me. I have a 2000 2dr 4wd blazer, the inside of my cat rusted out and would sit and rattle and drove me crazy so, i cut it out and put a piece of 2 1/2 straight pipe in, now the service engine light comes on i checked the codes, there is a code for the left bank 02 sensor and one for the right. I am not suprised this happened but i figured i would give it a shot it only cost me 13 bucks for pipe and clamps. Now what i wanna know is does any one know of a high flow cat and cat back exhaust combo that will work for my blazer and not effect the o2 sensors. I am looking for something that someone has already proven to work. for the cat back set up i am looking at the dynomax 19331 possibly but i have to look into what i'll have to do to cut it down to fit a 2 door, if the the only difference between the 2 and 4 dr exhuast is the length after the muffler it wouldnt be a problem
Old May 10, 2010 | 01:42 AM
RebelJimmy96's Avatar
RebelJimmy96 is on a distinguished road
get the magnaflow high flow cat and a Flowmaster super 44 muffler end of story
Old May 10, 2010 | 08:59 AM
PaulO2288's Avatar
PaulO2288 is on a distinguished road
Agree. I dont know how familiar you are with the different type of muffler sounds but check out youtube and go from there also. Get the high flow cat and then the muffler of choice and have a shop custom bend the pipe and install it for you. Probally your best bet and cheaper
Old May 10, 2010 | 01:26 PM
ZR2000's Avatar
I think the 44 is too loud for me, plus do either of you know it will work? The diameter of the pipe and the difference in the bends can make a big difference how do you know it wont trigger o2 sensor codes. that's why i wanted to find a high flow cat and cat back combo that someone has used because the pipe diameter and bends will be the exact same. Thanks for the advise but that's not quite what i was looking for.
Old May 10, 2010 | 05:08 PM
Phil's Avatar
The magnaflow catco cats are pretty good. Just register for the lifetime warranty and you'll be good. If it does throw a code (I've only heard of few cases where it did) then use an O2 fouler. For loudness, check out the Edelbrock SDT muffler on youtube. Sounds awesome. And the only difference is the length of the pipe on teh catback by Dynomax.
Old May 10, 2010 | 10:36 PM
PaulO2288's Avatar
The size of the pipe and the bends has nothing to do with emissions/throwing codes
Old May 11, 2010 | 05:13 PM
mine is 96 GMC Jimmy 4x4 4.3 Vortec
K&N FPKII Cold Air Intake
Magnaflow 9006 3" High-flow Cat
3" Pipe from Cat to 2 1/2 Inlet On A
Flowmaster Super 44 With 2 1/2 Outlet to A 2 1/2" y pipe
to dual 2 1/2 Pipes
and 3 " Echo Tip's
all Pipes are Mandrel Bent Aluminum steel
custom bent at Razorback Muffler where "NO MUFF TO TUFF"
http://www.youtube.com/watch?v=2C17oT7NsrY
Old May 11, 2010 | 09:48 PM
Phil's Avatar
About what RPM level were you revving to at the end of the video? Sounds good.
Old May 12, 2010 | 12:56 AM
between 2000-3000
Old May 12, 2010 | 12:10 PM
PaulO2288's Avatar
I have a Flowmster 40 with 2.5" Pipeing to a 3" Tip and it sounds the same but mine pops more :-) but i wish i could have gotten any place do to dual out like that. I tired so many places and they said they couldent do it and it sucks. How much did you pay?
