Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Rattle in my cataylic converter
Old Jun 26, 2011 | 08:50 AM
gavorlake's Avatar
gavorlake is on a distinguished road
Default Rattle in my cataylic converter
Any idea how to fix ???? this problem
Old Jun 26, 2011 | 12:52 PM
rriddle3's Avatar
It means the insides of the cat have burned out and broken up. You need to replace the cat.
Old Jun 27, 2011 | 09:34 AM
88Vic's Avatar
88Vic is on a distinguished road
Take it off and scrap it and put a new one in. Performance-Curve sells Thunderbolt cats very cheap and they're as good as any other cat.
Old Jun 28, 2011 | 12:49 PM
redcruiser's Avatar
redcruiser is an unknown quantity at this point
Mine did the same, rattle got worse and worse, then it started whistling, replaced mine with a sport cat and had a stainless steel exhaust fitted at the same time, cheaper than getting a standard one over here in the UK.
Old Jul 6, 2011 | 02:08 PM
Unicorn333's Avatar
Unicorn333 is on a distinguished road
I had the same thing happening with my 2000 4wd. I went to start her the other day and it backfired and I heard a BOOM underneath. Turns out I blew a hole in the seam of the muffler also. The muffler shop told me to replace the cat is an "Assembly" (one piece) from the manifold down. $928.00 for the whole deal including the muffler. Does this sound right?
Old Jul 6, 2011 | 03:03 PM
xgiovannix12's Avatar
i dont think they need to change the manifolds unless they got damaged
i payed 350 bucks from my cat converter all the way to the rear of the truck
then an other 40 bucks to get it put on since i was lazy . to me it sounds like there ripping you off a bit
Old Jul 6, 2011 | 04:13 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Mine was 300$ for the cat, instal, and a little bit of pipe.
Old Jul 6, 2011 | 05:37 PM
The CA emissions equiped trucks can get quite expensive if you have to replace all 3 of the cats (main cat and 2 pre-cats). Most places won't do it any other way but as a complete assembly.
Old Aug 19, 2011 | 02:48 PM
creteangel78's Avatar
creteangel78 is on a distinguished road
mine has back fired, rattled inside the exhaust, i kicked it and bent it in now its fine...I did find a vaccuum hose unpluged in the upper drivers side! short hose bout 6-7 inches sucking air in, cant find where it goes its attached to three other hoses that are hooked else where, but this one have no clue where it should be plugged into??? put a screw in the end of that hose and the motor idles down a few notches!!! I replaced wires and plugs it seems not to be missing any more and when it first starts up it dont put and spit, its running on all cylinders now..This hose is going to bother me, suck air in or not?
Old Aug 24, 2011 | 05:57 PM
appliancguy's Avatar
appliancguy is on a distinguished road
Default I Know
Believe that was for thr y pipe with both pre cats....Had mine replaced free under 70,000? miles emmision warrantee.
