Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
where to get headers
Old Mar 28, 2010 | 11:41 PM
9t54x4's Avatar
9t54x4 is on a distinguished road
Default where to get headers
ive looked on the web, read threads on here and i havent found the answer to my questions. will 2wd headers fit 4wd blazers?, where can i find 4wd headers? will porting the heads require larger than 1.5" primaries? & would it be cheaper to fab some block huggers yourself or just buy some production headers?
Old Mar 29, 2010 | 01:02 PM
You should be able to find 4wd headers. They'll likely be shorties. I believe that Edelbrock used to sell a set that included a larger y-pipe. Try contacting a few manufacturers and see what they come up with.
Are you going to be running a carb on this? If so, something in the 400-450cfm flow rate should suffice for a well built 4.3L.
Old Mar 29, 2010 | 07:29 PM
9t54x4's Avatar
thanks for the info.ive heard edelbrock headers throws codes for the o2 sensor,i tried to find them although but came up with the 2wd set.im running fuel injection.why the shorties only for 4wd,will they hit something or is something in the way? if i fab my own would 14ga tubing be to heavy guage for the 4.3?
Old Mar 29, 2010 | 07:33 PM
It's to get the y-pipe around the front driveshaft.
14ga shouldn't be a problem so long as you can work with it.
Old Mar 29, 2010 | 09:06 PM
9t54x4's Avatar
thanks for the info
mudcat
20
May 4, 2011 05:47 AM
grimreper912003
Oct 23, 2010 07:48 AM
90K5Blazer
Oct 7, 2009 10:01 PM
O_P_PLaya
Aug 13, 2006 02:00 AM
ivannj
Dec 22, 2005 03:28 PM
