-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   2" Rough Country Installed (https://blazerforum.com/forum/lifting-tech-44/2%22-rough-country-installed-17752/)
motoraser125 Feb 25, 2008 09:46 AM
Check out newpics in the gallery. I got to get new tires soon!
jphayes921 Feb 25, 2008 10:02 AM
RE: 2" Rough Country Installed
looks good, yeah I hear ya on new tires, but I am waiting to do a body lift. then get new tires.
94blueknight Feb 25, 2008 11:11 AM
looks tight! i was lookin into gettin this lift kit like end of summer (when i have money) was it pretty easy to install and stuff? how does it ride now?
nj4x4blaze Feb 25, 2008 12:06 PM
The lift looks great!!!!!!!!!!!
jimmyboy Feb 25, 2008 05:03 PM
looks good. do you have any pics of your cv angles?
jimmyboy
thegr81 Feb 26, 2008 03:05 AM
Lookin good!!!
nj4x4blaze Feb 26, 2008 06:05 AM
From the one photo it looks like you have the same issue i had with the lift, negative camber. Once you do the wheel alignment should fix that. I aggree I would like to see your cv angles as well.
motoraser125 Feb 26, 2008 07:31 AM
Thanks alot. I will be sure to take some pics of the cv angles as soon as I can. I already had an alignment done and everything checked out ok. I didnt get as much lift out of the back as I thought I would so I think im going to get AAL. Do youwhere I can get like 1" or 1.5" AAL.
Nate12 Aug 19, 2008 10:27 PM
To Motoraser125:
Have a blazer similar to yours besides mine is only 2 door. Have the same grille guard and lights howerver. Was thinking about getting the Rough Country Suspension Lift for mine. Just wondering if there were any problems you encountered and how your blazer rides after putting that lift on? Thanks
Nate12 Aug 19, 2008 10:30 PM
Have a blazer similar to yours besides mine is 2 door. Considering putting the Rough Country 2" lift on my blazer. Did you encounter any problems while putting it on? Also, how does it drive with that lift on. Kinda new to this whole thing so any suggestions would be appreciated. Thanks
