2" suspension lift
Old Aug 10, 2007 | 05:02 PM
Tomblazer's Avatar
Tomblazer is an unknown quantity at this point
Default 2" suspension lift
Where can i find one if they make them i googled it and the smallest i could find is a 5" for like 1700 dollars. To rich for my blood.
Old Aug 10, 2007 | 05:11 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: 2" suspension lift
yes. its called blocks and spindles
Old Aug 10, 2007 | 05:22 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Well if we had more specs about your blazer we could point you in the right direction.
Old Aug 10, 2007 | 05:31 PM
EuroGoldLS's Avatar
he has a 2000 4x4
Old Aug 10, 2007 | 05:44 PM
RCars2's Avatar
Oh......in that case. For 2 inches on suspension you dont have much choice other than cranking up the torsion bars and getting some shackles. Work pretty good but can cause front end wear. I still hold firmly that body lifts are the safest way to go. No wear, pretty easy to install, and you can go to 30" tires with no rubbing, 31" tires with minimal rubbing which can be fixed with trimming.
Old Aug 10, 2007 | 07:28 PM
Tomblazer's Avatar
ORIGINAL: RCars2
thanks and where do i find some shackles i did a google search and found ones that drop the blazer. And how much work is involed in this.
btw 2000 4x4 2dr ls.
Old Aug 10, 2007 | 10:38 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
You can get shackles from Synergy Offroad or 4 Wheel Parts. It is not that hard to do the shackles, hardest part would be removing the factory mounts. The t-bar crank is easy, all you need is a 19mm socket and put the vehicle on jackstands and twist a couple bolts. Do a search on blazerforum and you should be able to find out more how to do the t-bar and shackle installation.
Old Aug 21, 2007 | 12:41 PM
*Moved to Mods - Suspension - Lifting Tech*
Old Aug 21, 2007 | 01:42 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
euro, block and spindles will do nothing for a 4x4..... block will actually lower it.... as for a 2 inch lift kit, superlift and rough country both make one. It is a glorified T-bar crank, just includes new upper control arms which are pointless. A 2 inch lift just cranks your front end and can cause damage to ball joint, cv's, etc..you can crank and do shackles, but I wouldn't reccomend it for a DD.
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
