OK... so talking with my mechanic... he has put 2in body lifts on... but told me that if I were to do that and put bigger tires on i would be F***ing myself and just ruining my truck...
I put my bl on last year and can't believed I waited so long to do it. Hands down the best the best mod I've done.
As far as engine cooling, if you buy a kit with everything you need, vice just blocks and bolts, the kit will come with spacers for the fan shroud. As far as steering, some people need to elongate the bolt holes in the firewall to drop the steering column about a 1/4 of an inch. I know of only one or two that have had to do this. Luckily, I didn't have to. As far as installing a bl being the worst thing one can do, I'd be looking for another mechanic. There is only one reason people lift a vehicle and that is to put bigger tires on. The cheapest, and safe, way to do this is a bl. Using a proper kit rather than hockey pucks will not alter the safety of your vehicle, other than a slightly higher center of gravity. It does not effect the suspension in any way, does not cause improper wear on front end parts, does not effect the drive train in any way. I still do not understand why some folks are against body lifts. I can understand if you want to put a 10" bl on (yes, I've seen them) but there are no ill effects to a 2-3" bl if done correctly. |
Qusetion i have a 98 blazer LS 2wd 2dr and i would like to put on a bl(2in).. so my question is the tires i have on right now are 215/70/15 would it look funny once the lift kit is install with this tires... thanks
Originally Posted by Sniper 78227
(Post 241699)
A body lift without bigger tires is a little redundant IMO. The reason body lifts are available is to be able to make room for the bigger tires. If you put the BL on, and don't change tires you really don't gain anything. Why bother with a body lift then?
Originally Posted by dimone545
(Post 241702)
You should get meatier tires if your going to lift it at all. Hell I would get meatier tires even without a lift but I just hate the way stock tires look.
can anyone tell me what would be some go size meatier tires size i have the chevy alloy rims 15'' thats true i do have the stock look i think ill called discount tire see if i can change them out there only 6 months old and have a 65,000 mile wrty. thanks |
without a body lift the biggest tire you can get is a 30/9.5/15, with the body kit a 31/10.50/15 would fit really nice. With you currently having 215/70's, a 30/9.50/15 would probably make you pretty happy, plus once you get your BL on there they will still look pretty decent. If you have they money ready for tires now, try some Procomp all terrains, they are on sale buy 3 get 4th free, so it will save you a little bit of money. My bridgestone deulers a/t ran about $560 or so, I love them. In the snow I actually had to put it in 2 wheel drive just to have some fun, and they were still gripping pretty good.
Just dont get something that is a beefed up mudder if its your daily driver and you driver it on the highway, because they arent going to last very long, go with a beefy all terrain tire, hope this helps. |
thanks Boopappa
this is very helpful i'm going to look for some 30/9.5/15 and see what i find . my stock tires cost me 524 after instanlled :icon_doh: |
i wanted to put a lift in my 02 blazer 4 door 4x4 but i really dont want to spend alot. i found a rear lift 2" for $60 but the front was $800 any suggestions?
