2 in body lift
Old Feb 14, 2011 | 09:28 PM
Josh1573's Avatar
Josh1573 is on a distinguished road
Exclamation 2 in body lift
I have a 1997 blazer, I want to put in 2in body lift on. whats the biggest tires i will be able to fit with just a 2in body lift?
Old Feb 15, 2011 | 09:02 AM
chevytruckdood's Avatar
Use the search feature. you can really find a lot of info. yes its a little bit of work but in the end its worth it... every question ive had has been asnwered in these forums numerous times.
Old Feb 15, 2011 | 10:18 AM
oktain's Avatar
I suggest taking a look at the "stickies" whenever you open a subforum, they're there because there's tons of info and alot of FAQ's are answered in them.
https://blazerforum.com/forum/lifting-tech-44/start-here-lift-kit-list-16186/
Old Feb 15, 2011 | 07:04 PM
blazinloud's Avatar
31's is my guess, but you might need to trim still.
Old Feb 15, 2011 | 08:58 PM
Josh1573's Avatar
Thanks guys, I've searched around on here a lot and couldn't really find a straight answer
Old Feb 15, 2011 | 09:15 PM
AJBert's Avatar
You can fit 35's no problem!
Just don't try to drive it let alone let it off the lift/jack stands.
Old Feb 17, 2011 | 08:35 PM
Moores12345's Avatar
Moores12345 is on a distinguished road
Should be able to get 31's in there without trimming but don't quote me on that because I don't have mine yet. Should be able to get 32's with a 2" BL, t-bar crank and 2" shackles in the back.
Trimming is minor stuff if it's your truck.
I always liked the max-d look..the real cut out fender look that is..
Old Feb 17, 2011 | 09:46 PM
Jerb's Avatar
Jerb is on a distinguished road
seems like every blazer is a little different, but even with a 2'' body lift, plan on doing dome trimming to the bottom corner of front fender, rears are usually fine, if you run stock rims, may or may not have to trim, but 10.5'' wide tires really should be on a wider than stock rim, and its the offset on aftermarket rims that cause the problems with hitting the fenders, my 15x8 with 4'' bs, and 30x9.50 tires are gonna need a fender trimming so i don't have to worry when i go off-roading!
Old Feb 17, 2011 | 10:36 PM
NVANZEE's Avatar
It depends on what you do with it. You might be able to fit 31x9.5 on stock rims IF you keep it on the road. They might rub slightly on bumps. If you go off-road with it they will rub quite a bit. Theres a lot of factors that will determine if they fit or not. Actual tire height and width (the size on the tire is not always accurate), wheels, where you drive, 2wd or 4wd, how much your suspension is sagging, etc..
Old Feb 18, 2011 | 08:12 AM
Josh1573's Avatar
how much would a 2in body and a 2in suspension run me?
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
