2 inch lift problems
well stock size, 235/75r15 is pretty much a 29 inch tire. so if you are looking to put 30's on, you are only talking about 1/2 inch on each side. if you look in lifting tech, there should be a sticky that you can start at. it should tell you what you need to fit what you want.
i wound the front torsion bars up to there max then had the rear leaves reset to the same height and with just a touch of trimming just behind the lower rear section of the front flares.i got 31.5x10.5 Micky T's under my 2000 model t10 [right hand drive s10] 4x4.its very hard on idler arms and cv boots tho less than 6000 kilometers to a idler arm and about 10000 out of the boots.i suggest put tall upper ball joints in at the same time to correct the camber a little at the same time that's assuming the left hand drive series has the same wheel align issues as the ones we get here.
Bigtimblazer
Lifting Tech
Nov 30, 2011 06:01 PM
blazinUP
Tires and Wheels
May 14, 2010 08:06 PM
