2 inch lift problems
Old Jun 23, 2013 | 01:49 PM
01blazer16's Avatar
01blazer16 is on a distinguished road
Post 2 inch lift problems
I was wondering has anybody had any trouble with the 2 inch Rough Country Lift because i was thinking about getting it for my blazer?
Old Jun 23, 2013 | 03:49 PM
Twip's Avatar
2wd? or 4x4? from the picture it looks like a 2wd. so you would need some coil spacers and and some shackles in the rear.
Old Jun 24, 2013 | 06:25 PM
01blazer16's Avatar
Yea 2wd and would that fit 30s?
Old Jun 24, 2013 | 08:14 PM
Twip's Avatar
well stock size, 235/75r15 is pretty much a 29 inch tire. so if you are looking to put 30's on, you are only talking about 1/2 inch on each side. if you look in lifting tech, there should be a sticky that you can start at. it should tell you what you need to fit what you want.
Old Jun 24, 2013 | 08:23 PM
El_Beautor's Avatar
Most people can squeeze 30's on factory S-series Blazer rims without any lift at all, 2wd or 4wd. If you go with the 2" lift you should be golden.
Old Jul 29, 2013 | 03:53 AM
blazer down under's Avatar
blazer down under is on a distinguished road
i wound the front torsion bars up to there max then had the rear leaves reset to the same height and with just a touch of trimming just behind the lower rear section of the front flares.i got 31.5x10.5 Micky T's under my 2000 model t10 [right hand drive s10] 4x4.its very hard on idler arms and cv boots tho less than 6000 kilometers to a idler arm and about 10000 out of the boots.i suggest put tall upper ball joints in at the same time to correct the camber a little at the same time that's assuming the left hand drive series has the same wheel align issues as the ones we get here.
Keeler
Lifting Tech
22
May 29, 2010 03:53 AM
blazinUP
Tires and Wheels
May 14, 2010 08:06 PM
brino1
Dec 16, 2009 04:17 PM
mikehillis1@yahoo.co
Suspension Tech
Nov 10, 2006 08:24 PM
