2001 2WD lift question (My question regards the spindles)
Old Dec 21, 2010 | 02:02 PM
2001Blue's Avatar
2001Blue is on a distinguished road
Default 2001 2WD lift question (My question regards the spindles)
So I have been digging through the forum on lifting my 2001 2WD 2DR Blazer. I have seen it referenced between lifting springs, spindles, body lifts etc etc. I dont really want to do a body lift because I mostly need the ground clearance on the frame and stuff for where I go off roading at. I dont have to worry about mud so much cause well its all still frozen around that time of year
Anyway, I looked up spindles and I can find spindles for the s10, but they all say that the spindles will not work after the 1997 blazer but will work until 03 or 04 on the s10s. anyone know why this is? Or who sells spindles for a 2001 2WD. I can go with a spring lift kit and new upper a arm but I have read that the ride gets a little rough, and this is still going to be a daily driver.
Old Dec 21, 2010 | 10:36 PM
Phil's Avatar
Coil spacers are supposed to be good for lifting the front on a 2WD. Those upfront and shackles on the rear will give you 2".
Old Dec 31, 2010 | 02:17 AM
nalgman's Avatar
nalgman is on a distinguished road
Default question
i have a similar question about the lifting of a 2w blazer
i have a 1990 2wd blazer.
this blazer have a 2.5" lift but i don't know how they lifted up..
it doesnt have coil spacers, or replaced spindles...
i looks good.
but here is what i want to know..
in the road it jumps a little in a bump or it feel the suspension hard...
so, what can i do to make it more soft??
put some coil spacers?? or bigger coil springs?
thank you very much...
Old Jan 1, 2011 | 08:09 AM
ScottyBoy98's Avatar
ScottyBoy98 is on a distinguished road
The reason the spindles wont work for the blazer is the dual piston brakes, s10 pickups have a single piston...if you swap for some s10 pick up brakes then the spindles will work and not change your ride quality...a few people have done this that i know of, speterson1011 being one of them
i looks good.
it probably already has bigger coil springs on it to give it the 2.5"...upgrading the shocks would be the way to soften up the ride
Last edited by swartlkk; Jan 1, 2011 at 01:06 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your and use the multi-quote feature to reply to more than one person.
Old Jan 1, 2011 | 11:28 AM
mov4x4's Avatar
mov4x4 is on a distinguished road
Rancho makes some shocks called "quick lift" and they will work on the 2wd because it has coil springs and they raise it 1.5 to 2 inches I think.
Old Jan 1, 2011 | 07:15 PM
matt92's Avatar
matt92 is on a distinguished road
Spindles require swapping the rotors and calipers with those of an s10. Coil springs, shackles, add a leafs, and some shocks for the front would be the easiest and cheapest.
Kaegael
Aug 6, 2014 08:40 PM
speterson1011
Lifting Tech
Dec 7, 2009 11:13 AM
01extreme
Suspension Tech
Apr 6, 2007 11:24 PM
blazerxtreme1
Suspension Tech
Jan 20, 2006 07:31 PM
