2001 jimmy lift kit questions. (Torsion key/shackle)
Going to lift my jimmy and put on bigger tires and rims. I am going go buy torsion keys off of eBay and I already have the rear shackle lift kit and that part of the job seems easy but it's the torsion keys that have me worrying I watched a video on YouTube that basically gave me and idea about how I should swap out the old keys for new ones and I feel confident about it.
Just looking for some feedback on a tire and rim setup I will be able to run with the rear shackles raised 3" and the torsion keys raised 2" and what other modifications I will need to make
Also looked into a body lift but seems like a serious project how much work is it to install??
Any feedback about the installation or any tips would be great
THANKS!!!
THANKS!!!
Thanks. I saw on another thread that one full clockwise turn is about .25" is this true? And once I put the rear shackle lift in and turn the keys up will I be able to fit 31's on it with some sort of wheel spacer or fender modification???
As for fitting 31's, mileage varies a lot, but it is possible with just a t-bar lift if you're willing to trim the back of the front fender a bit. Depending on the tire you choose you will likely rub on the frame and sway bar. That's where the wheel spacer or rims with lower back spacing comes in. Which also adds to the need to trim your fenders.
Make sure you mark your the t-bar bolts and have a reference mark on the frame so you know exactly how much you've turned it.
BlaziNator
14
May 17, 2011 07:21 AM
