3" lift
Old Mar 27, 2008 | 05:21 PM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
Default 3" lift
http://cgi.ebay.com/ebaymotors/S15-B...mZ230229154854
Yay or Nay?
I think it could work. BUt im not the best when it comes to mechanical.
Old Mar 27, 2008 | 05:54 PM
jphayes921's Avatar
jphayes921 is an unknown quantity at this point
Default RE: 3" lift
not worth it just get some shackels from synergy off road or 3 leaf fab and a tbar crank the keys allow to over crank the bars and will put alot of stress on ball joints and high angles on the cv shafts. If you want 3" go with a body lift for the first gen. use the search in the forums and youll find lots of info.
Old Mar 27, 2008 | 05:56 PM
WolfPack's Avatar
Default RE: 3" lift
nay. 3' torsion bar lift = exploding front end.
And thats $150 shipped...pretty pricey considering it still only 2' shackles. This 'kit' is like the core of the Rough Country 2' lift...but apparently different keys, and without the re-angled control arms to help with ball joint wear.
I dunno..someone might consider it a yay...but I wouldn't put this on my blazer.
Old Mar 27, 2008 | 06:01 PM
Default RE: 3" lift
ok cool.
Wolfpack i noticed that you have 30x10.50, would those fit on 15X8 rims?
Old Mar 27, 2008 | 06:17 PM
WolfPack's Avatar
Default RE: 3" lift
I'm running 15x8s....so yes..yes they would
Old Mar 27, 2008 | 07:16 PM
95BlazerLt4wd's Avatar
95BlazerLt4wd is an unknown quantity at this point
Default RE: 3" lift
and considering you have a 2000, that wouldnt fit your blazer anyway... those shackles look like i could snap them like a pencil...
Old Mar 27, 2008 | 07:51 PM
Default RE: 3" lift
yeah stupid question, sorry.
An wolfpack, do you rub at all? Any lift to make those fit?
Old Mar 27, 2008 | 08:50 PM
WolfPack's Avatar
Default RE: 3" lift
I've got a 1.25' lift up front, 1.5' up in the back, and I cut at the back of the wheel well to allow normal turning (also removed the lowest bolt on the wheel well cover). Now I only rub at absolutely full lock with a bit of suspension compression...but only on the wheel well cover, which I plan to trim in the near future, but for now, I just plan ahead and don't look for the tightest parking spots.
Most of my rubbing issues are due to the 4.5' of backspacing on my rims, which puts the wheel in the danger zone with the fenders. I believe with stock 6' of backspacing you'll avoid the fender issue and touch the frame, which doesn't provide a cutting danger to the tire like the fender can.
Old Mar 27, 2008 | 09:05 PM
Default RE: 3" lift
So if i dont want to deal with any rubbing at all what backspacing wuld you recommend
Old Mar 27, 2008 | 11:27 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: 3" lift
30x10.50's will fit on a stock 15x7 rim
