3" lift kit help for 96 4 door.
Old May 2, 2007 | 03:05 PM
phatsrfr's Avatar
phatsrfr is an unknown quantity at this point
Default 3" lift kit help for 96 4 door.
im considering a 3-4" lift for my 96 automatic 4 door blazer. dont know anything about lifts so any info would be a great help. all i know is that i wana get higher off the ground and new muddin tires and rims. everything you know would be a help. from prices to instalation places, anything
Old May 3, 2007 | 11:13 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: 3" lift kit help for 96 4 door.
Well, unfortunately there isn't a 3 or 4 inch kit for your blazer. You could go with a 2 inch suspension and a 2 inch body or a 2 inch body and a T-bar crank, but just a warning, the t-bar crank can cause premature damage to your ball joints, cv shafts, etc...
Old May 3, 2007 | 04:47 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Actually there is a 4 inch lift from trailmaster buts its not cheap by any means. I would reccomend the t-bar crank and body liftlike a_tack suggested. Its what im gonna do and you can get both from ebay for under $400 shipped collectively.
bigdaddykane93
Feb 24, 2013 02:30 PM
Jkrumm
Lifting Tech
Feb 17, 2011 04:35 PM
jjsmith1228
Oct 31, 2010 03:56 PM
ericthughes
Lifting Tech
Oct 13, 2010 10:56 PM
COUNTRYBOY061488
Aug 28, 2008 07:54 PM
