33's?
Old Jun 28, 2008 | 09:38 PM
4x4 cc's Avatar
4x4 cc is an unknown quantity at this point
Default 33's?
How much lift do I need at the minimum to fit 33's under a stock blazer? Thanks Alot, -Austin
Old Jun 28, 2008 | 10:09 PM
WolfPack's Avatar
Default RE: 33's?
1) why do you want 33's
2) what kind of vehicle are you driving?
3) are you aware there is a search feature on this fourm?
Old Jun 28, 2008 | 11:05 PM
4x4 cc's Avatar
Default RE: 33's?
1: I have a Ford on 44's and this is my daily driver so 33's is really as tall of a tire I'd like to go.
2:1998 4x4 Blazer
3: I found it right after posting all of my questions...
Thanks, Austin.
Old Jun 30, 2008 | 03:58 PM
95BlazerLt4wd's Avatar
95BlazerLt4wd is an unknown quantity at this point
Default RE: 33's?
some guy on here had 33's with two inches but i dont think that worked out so weel because as far as i know he has 31's on now, im running 33's with 4"s of lift with no problems other than some rub. but no dd problems, only when turning i rub the frame on an extreme turn.
Old Jun 30, 2008 | 10:26 PM
95_4door's Avatar
95_4door is an unknown quantity at this point
Default RE: 33's?
I had a 2" lift and 33s cleared on stock steel rims. I had full turn, lock to lock. You couldn't do a whole lot of "playing" since there wasn't that much clearance. When I put the on monte carlo rims, I had steering issues. I switched to 31s on my monte rims and it looks nice.
[IMG]local://upfiles/7885/290891E75D09470397B04B1AFFD17914.jpg[/IMG]
