-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   3inch body lift questions (https://blazerforum.com/forum/lifting-tech-44/3inch-body-lift-questions-27470/)
dalifts Feb 11, 2009 06:40 PM
i have a 94 s10 chevy blazer 4door automatic 4x4 4.3 vortec v6.i have a peformance acc. 3 inch body lift im going to install. i have questions about steering column do i have to get a different one or will mine work? i understand the 4x4 actuator vacum has to use spacers and gas fill extnded what other modifications are neaded?
Outsydr Feb 11, 2009 07:08 PM
RE: 3inch body lift questions
94 requires a steering extension (part # 9907 from These Guys) I've spent quite a bit of time researching the different kits for my 94 and BDS seems to be far and away the best bang for your buck (bumper brackets, gas filler ext. etc are all included) only extra item required is the steering extension and they make sure to inform you of that up front.
SockJock Feb 11, 2009 09:01 PM
You can also go to performance accessories website and read the instructions for your application and it should tell you about any special modifications/parts needed to complete the body lift.
dalifts Feb 11, 2009 09:47 PM
i think that it came with it. there is like 2 peices of metal with holes on each end. one hole on each of the metal peices are little bigger then a normal hole for adjustment ? if you can confirm or gimme a pic of what its suppose to be id appreciate it. thanks
and do i have to worry about my transmission cuz its automatic
dalifts Feb 11, 2009 10:36 PM
im never did a body lift kit before and i hate instructions. I know cut gas hose to make longer. i know how to put the spacers in. fan shroud trim. and the vaccuum actuator for the 4x4. I already purchased the performance accessorys 543 3inch body lift kit. I glanced at the instructions there's like 3 different ones in the book for different vehicles gets me confused. It shows something about moving the steering columb down and making new holes? idk if anyone has any pics or info please let me know i wanna do this this weekend. thanks
bammontana Feb 12, 2009 06:55 AM
Yours sounds like a little more work then mine, but I have a 99. In my case, I started Saturday Morning and Ended at 10 oclock last night ( keep in mind Monday Tuesday and Wednesday were only half days like 4-10 because of work)
Most of it was bastard OEM parts on the truck that did not want to come off, etc. Will I do one again? Only if I have Jack Daniels readily available.
dalifts Feb 15, 2009 11:09 AM
ok i installed the body lift kit 3inchs. Had no real problems with it. 2 steel lines broke for the transmission but they were all rusted so just replaced them glad it did it in the garage not on the street. Now the only thing is there is binding in my steering. Thats from not having the steering extension right ? now only one i can find online is a 2inch from bds any others that fit 3 or is the 2 enough ? if so imma over nite it tomorrow. thanks the blazer looks badass now
dober Feb 25, 2009 05:10 PM
what year blazer do you have?
Cavalier z24 Feb 25, 2009 05:45 PM
he has a 94 s10
dober Feb 25, 2009 09:17 PM
ive decided to go with a 3" on my '01 blazer. one question i have is should i get differant shocks or are they not affected by the bL
