5" trailmaster lift?
Well im gonna go out on a limb here and figure that you own a second gen s-series blazer as i think trailmaster only makes a second gen kit. As for the trailmaster kit, its pretty decent. Little costly like the rest but not bad. Honestly though i might steer ya toward the superlift 6" kit as the price between the two is pretty close and ya get an extra inch of clearance.Now if ya lived in arizona thats a different story as you can head up to prescott valley to where trailmaster makes these lifts and they are a little bit cheaper in person but thats a technicallity.
im going for both funciton and looks its a 99 blazer 4dr 4wd and i just don't like how it sits now i bent the **** out of my crossmember trying to ride over my jump out back and my old blazer i had no problem doin that but i also want to go mudding so i want bigger tires so yea but i don't like body lifts and u can already see my frame rails so anything else?
Well, looking back at your original post i now noticed the wanting it cheap part. Bad news is that most good larger lifts are not cheap, if anything they are really friggin expensive. You're against body lifts so thats out (though with gap covers and some black paint you wouldnt notice the gap but you still dont gainany ground clearance unless you get bigger tires), torsion bar adjustment will help ya some and its cheap but its only 1.5"-2" of adjustment and it wears out the front end so thats probably not all that helpful, probably your best bet would be to find ya a good set of used front and rear axles off a jeep or whatever you can find and convert the front end to a solid axle with leaf springs. Mount the leafs on top of the axles and if ya do it right you get about 6" of lift, more depending on if you use shackles or different leaf springs. Now granted this method isnt cheap either but if you do the work yourself you can save a boatload of cash.
If trailmaster is the cheapest by a good margin over the superlift then go for it. As for other options there is one more and thats BDS suspensions, which has a 5" kit but its more expensive than the superlift kit last time i looked at them so its probably not worth it. If ya find it cheap though then give it a shot.
So far nothing bad that ive heard with trailmaster. The kit is very similiar to the superlift kit and i think it does have the advantage that you dont have to cut a crossmember like the superlift kit but dont quote me on that. At any rate i dont believe that the trailmaster kit will do ya wrong. Ive ridden in a few s-10's that have it and another that had the superlift and they rode about the same so near as i can tell you can go either way.
