6 inch lift: need one
So I'm going ahead with lifting my blazer.
I have the rims and tires picked out, but all i need is the lift.
I'm gonna go for a 6 inch lift, but I need to find the right one. and so far There all pretty expensive ($2000 ish)
So I need help to find me a reasonable 6 inch lift around that price range if not lower. Help is greatly appreciated!
So far its looks like I'm swinging to the TrailMasters ( http://www.autoanything.com/suspensi...0A2345496.aspx )
But i did find this one for less, ( http://www.jackit.com/store/supercar...s=rcd_10-41089 )
Thanks if you's can help!
P.s. Its a 1998 Chevy Blazer 4wd 4 door if that helps any
Alrighty, sounds good!
I did some looking up and it says that its only available for the Zr-2 only?
Would the Zr-2 parts fit normally on my 4 door? or is there another specific kit for it?
From my dealings its getting harder to find this kit, so just go straight to superlift, they will either point you to the distributor or possible order direct. we found cheapest online and had a helluva time. we ended up canceling it, it ended up being backordered thru them and they didnt tell us, til 3 weeks later. we ended up going thru someone local that was willing to meet the price we found luckily. summit still sells the kit but it was also backordered when we looked.
