8 inch lift help
Old Jun 3, 2009 | 12:24 AM
f6artipower's Avatar
f6artipower is an unknown quantity at this point
Question 8 inch lift help
i have an 86 k5 with a 6.2 im lifting it 8 inches but i wanted to knwo everthing ill need i have a good idea but i just wanna hear from all the guys that have already done it thanks,
Old Jun 3, 2009 | 01:02 AM
bandidolenny's Avatar
So you are using 8" leaf packs front and rear?.. If not, I don't recommend more than a 4" block in the rear. And DO NOT use blocks in the front. Off the top of my head you will need:
-To extend both drive shafts
-Longer front brake lines
-Longer diff tube vents
-Raised steering arm
-Longer shocks to match the lift
-Swaybar lowering blocks
On a side note: Once you install the lift, don't pull yourself up into the vehicle via the steering wheel... tends to mess up tilt steering columns.
Old Jun 3, 2009 | 05:24 PM
for the steering arm how big do i need to go i saw some 4 and 6 inch but will taht work with my 8 inch kit? do i need a transfer case drop? also wheres the best website to buy all this?
Old Jun 3, 2009 | 08:32 PM
Check out this sight for more ideas.
http://www.superlift.com/Catalog.asp?P=K423&V=92
JBlaze2K
Suspension Tech
Nov 5, 2013 04:44 PM
Keeler
Lifting Tech
22
May 29, 2010 03:53 AM
MikeRo
Lifting Tech
13
May 29, 2010 01:32 AM
blazinUP
Tires and Wheels
May 14, 2010 08:06 PM
