93 Fullsize Blazer, unknown lift...help
I cannot get the info I need from the previous owner, so I am stuck on my own for this. It came with 33 inch tires on it, no mods to the fenders, and no body lift.
So, is there a way I can figure out what type of lift is in it or the height?
From ground to the bottom lip of the fender is 39 inches. I have tried looking on my own for this answer, but have yet to have any luck. Attached is a pic before the tear down should it help as well.
Thanks. With that information, I decided to just go ahead and get a 4 inch lift for it. There was so much tweaking done on this from the past owner, I have to inspect near everything on it.
On the down side, I have seen the cost of a 4 inch lift for a 93....good thing i was sitting down when I looked!!!!!!
I have not purchased a lift for it, but after the suggestion mentioned, I looked closer and it seems Jamaroon was correct about the t-bar crank and shackle type of lift.
The current plan is to do a 3 inch body lift and 4 inch suspension lift with this project.
XxIRISH63xX
Dec 13, 2011 06:32 PM
eastsiderides
Jan 2, 2008 10:08 AM
