93 Fullsize Blazer, unknown lift...help
Old Aug 27, 2013 | 10:09 PM
TOTWM's Avatar
TOTWM is on a distinguished road
Default 93 Fullsize Blazer, unknown lift...help
I cannot get the info I need from the previous owner, so I am stuck on my own for this. It came with 33 inch tires on it, no mods to the fenders, and no body lift.
So, is there a way I can figure out what type of lift is in it or the height?
From ground to the bottom lip of the fender is 39 inches. I have tried looking on my own for this answer, but have yet to have any luck. Attached is a pic before the tear down should it help as well.
Attached Thumbnails 93 Fullsize Blazer, unknown lift...help-img_2979.jpg   93 Fullsize Blazer, unknown lift...help-img_2977.jpg
Old Aug 28, 2013 | 07:47 AM
Jamaroon's Avatar
My guess would be just a t-bar crank and shackle type of lift if it even has anything. So probably about 2" lift max.
Old Aug 28, 2013 | 08:12 PM
TOTWM's Avatar
Thanks. With that information, I decided to just go ahead and get a 4 inch lift for it. There was so much tweaking done on this from the past owner, I have to inspect near everything on it.
On the down side, I have seen the cost of a 4 inch lift for a 93....good thing i was sitting down when I looked!!!!!!
Old Aug 28, 2013 | 09:53 PM
Jamaroon's Avatar
I don't really know anything about fullsizes though, so I would suggest trying a bit more research incase I'm wrong.
Old Sep 2, 2013 | 04:30 PM
kwbond's Avatar
kwbond is on a distinguished road
Hey TOTWM
Did you ever buy a lift? Did you fined out how it was lifted by the previous owner?
I want to run 33 but do not want to add a 6 in lift
Thanks
Kyle
Old Sep 2, 2013 | 11:11 PM
TOTWM's Avatar
I have not purchased a lift for it, but after the suggestion mentioned, I looked closer and it seems Jamaroon was correct about the t-bar crank and shackle type of lift.
The current plan is to do a 3 inch body lift and 4 inch suspension lift with this project.
redsl
Feb 13, 2013 02:14 PM
RedOne
Feb 28, 2012 04:32 PM
XxIRISH63xX
Dec 13, 2011 06:32 PM
cory.kiel
Apr 20, 2011 06:52 AM
eastsiderides
Jan 2, 2008 10:08 AM
