95 blazer 3 in body lift... please help...
I have a 95 blazer with a 3in body lift... I was wanting to know if i put 3in blocks in rear and lifted keys on it will i need to extend on lines or wires... Please help... I also have 32x11.5x15 that rub a little... That's y i wanted to get a little more height... Also does anyone know if you can buy front shock extenders...
Your blazer is SUA in the rear so blocks will lower it. You need shackles or AAL. Stock length shocks will work just done for what your wanting to do. As for lines and wires everything should be ran along the frame so just double check everything after the suspension lift is done (whatever it is that you choose to do) and you should be fine.
you may have to. when i but the BDS on my 99 i had to extend the brake lines about 6".
as far as the rest of the questions i dont know. |
Throw in add a leafs and 1.5 t bar crank and you`ll be good to go
T bar cranked already i will look in to add leaf... Thanx...
