95 blazer 3 in body lift... please help...
Old Oct 22, 2013 | 07:06 PM
bschick's Avatar
bschick is on a distinguished road
Default 95 blazer 3 in body lift... please help...
I have a 95 blazer with a 3in body lift... I was wanting to know if i put 3in blocks in rear and lifted keys on it will i need to extend on lines or wires... Please help... I also have 32x11.5x15 that rub a little... That's y i wanted to get a little more height... Also does anyone know if you can buy front shock extenders...
Old Oct 22, 2013 | 07:14 PM
rexmburns's Avatar
Super Moderator
Your blazer is SUA in the rear so blocks will lower it. You need shackles or AAL. Stock length shocks will work just done for what your wanting to do. As for lines and wires everything should be ran along the frame so just double check everything after the suspension lift is done (whatever it is that you choose to do) and you should be fine.
Old Oct 22, 2013 | 07:15 PM
warthogdriver's Avatar
you may have to. when i but the BDS on my 99 i had to extend the brake lines about 6".
as far as the rest of the questions i dont know.
Old Oct 22, 2013 | 07:20 PM
newguy's Avatar
Throw in add a leafs and 1.5 t bar crank and you`ll be good to go
Old Oct 22, 2013 | 07:51 PM
bschick's Avatar
T bar cranked already i will look in to add leaf... Thanx...
Blaze14
Lifting Tech
Jul 10, 2011 07:33 PM
ZoeZR2
Apr 25, 2011 02:34 PM
SmoyMoose
Mar 30, 2010 07:41 AM
SmoyMoose
Lifting Tech
Mar 11, 2010 09:57 PM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
