96 blazer for off road and dd
I want to make my 96 blazer 4door a good off roader and a dd any help thanks
RE: 96 blazer for off road and dd
What are you willing to do to your truck? What are you looking to spend? There are multiple things you can do. You have a choice of a 2", 5" or 6" Suspension lift kits. They can run from $700 to $2,000.00(rough numbers). Or you do a 1.5" t-bar crank and lift shackles. These options you can run as a daily and some off roading. Also since you are going to lift the truck and run bigger tires look into upgrading your front and rear gears to 4.11's. You are also going to need a power programmer to calibrate your speedometer for the bigger tires.
i will have about $1940 for lift and tires what can i do with that i do have $2600 but i want to get a brush guard and some outher stuff. thanks
well get you a set of these tires
http://www.4wheelparts.com/Tires/BFG...&t_pn=BFG87961 and im getting those with a 2in body lift and a brush guard a set of those tire will run about 600 bucks a body lift runs 200-500 bucks body lifts are alot easier then suspension lifts just my .02 |
