96 blazer for off road and dd
Old Oct 22, 2008 | 05:57 PM
96blazeroffroad's Avatar
96blazeroffroad is an unknown quantity at this point
Default 96 blazer for off road and dd
I want to make my 96 blazer 4door a good off roader and a dd any help thanks
Old Oct 22, 2008 | 06:25 PM
nj4x4blaze's Avatar
Default RE: 96 blazer for off road and dd
What are you willing to do to your truck? What are you looking to spend? There are multiple things you can do. You have a choice of a 2", 5" or 6" Suspension lift kits. They can run from $700 to $2,000.00(rough numbers). Or you do a 1.5" t-bar crank and lift shackles. These options you can run as a daily and some off roading. Also since you are going to lift the truck and run bigger tires look into upgrading your front and rear gears to 4.11's. You are also going to need a power programmer to calibrate your speedometer for the bigger tires.
Old Oct 22, 2008 | 06:27 PM
nj4x4blaze's Avatar
https://blazerforum.com/m_123415/tm.htm
Old Oct 22, 2008 | 06:55 PM
i will have about $1940 for lift and tires what can i do with that i do have $2600 but i want to get a brush guard and some outher stuff. thanks
Old Dec 2, 2008 | 04:55 PM
stevo's Avatar
stevo is an unknown quantity at this point
well get you a set of these tires
http://www.4wheelparts.com/Tires/BFG...&t_pn=BFG87961
and im getting those with a 2in body lift
and a brush guard
a set of those tire will run about 600 bucks
a body lift runs 200-500 bucks
body lifts are alot easier then suspension lifts
just my .02
Meganutter
Sep 4, 2013 01:58 AM
maroman88
Oct 2, 2010 11:21 AM
nathanfoudray
Jun 23, 2010 12:41 AM
raza514
Mar 14, 2010 12:36 PM
Tetenok
Jan 19, 2008 05:09 PM
