Add a leaf or shackles???
Old Jun 4, 2012 | 10:36 PM
SOB1999JIMMY's Avatar
SOB1999JIMMY is on a distinguished road
Default Add a leaf or shackles???
Whats the best method pros and cons of each What made you chose???
Any brands you might recomend prices and problems you encountered...
Old Jun 7, 2012 | 10:18 AM
99bblazer99's Avatar
99bblazer99 is on a distinguished road
i find shackels alot easier the add a leaf. ive only had experinces with shackels tho. there not much diference with them add a leaf, ubolts and shackels all do the same thing.
Old Jun 7, 2012 | 10:43 AM
Jamaroon's Avatar
I did both on mine, adding the extra leaf was easier than the shackles because my bolt were seized in the bushings so I had to get new bushings as well. The add-a-leaf will help out when towing or hauling anything and the shackles won't.
It's a good idea to get new hardware regardless of which one you end up doing before you start. Bolts for the shackles, and u-bolts and center pins for the add-a-leaf.
Old Jun 7, 2012 | 11:44 AM
El_Beautor's Avatar
The other thing to remember with the add-a-leaf is that while it will make it so your back end doesn't sag as much when carrying a load or towing, it will also make the ride stiffer in the rear when you're unloaded. This may be fine depending on what you want.
Old Jun 7, 2012 | 12:06 PM
serrasalmus's Avatar
serrasalmus is on a distinguished road
i have a add a leaf and it didnt make it any stiffer,still rides like a certain buckin little paint baby i know. i think thats due to the cheap **** shocks i used. i did notice however it didnt seem to lift it the full 2 inches like it says it would. on the shackle ive heard that it adds more side to side sway sometimes but dont know for my self
Old Jun 7, 2012 | 07:48 PM
I'm considering both if your gonna do it do it right. Right?
Old Jun 7, 2012 | 09:19 PM
Rottidog's Avatar
If lift & load carrying is what you want there are air bags you can add inbetween the leafs & frame. I'm thinking of that for towing the boat to level it better.
If the leafs are flattening out without a load then consider replacing them & based on how that goes, think about shackles &/or add a leaf or possibly air bags that naturally are adjustable depending what you need at any certain time.
Old Jun 9, 2012 | 09:41 PM
I want to lift it with the Rc 2.5" and the add a leaf's what I really need to do is less talk more work beacuse stock sucks
Old Jun 9, 2012 | 10:17 PM
Rottidog's Avatar
Originally Posted by SOB1999JIMMY
I want to lift it with the Rc 2.5 and the add a leaf's wat I dealt need to do is less talk more work Cu's stock sucks
I'm sorry, I've had a few beer & possibly my house has a C0 leak as well... but what did I just try to read?
I will say I'll agree with the talk less part - if that was a part. lol
Old Jun 10, 2012 | 01:32 PM
sorry that was from my phone stupid *** touch screens i fixed it
