Adding 2" BL to a 2" RC Suspension Lift
Old Jan 11, 2009 | 12:26 PM
Nate12's Avatar
Nate12 is an unknown quantity at this point
Default Adding 2" BL to a 2" RC Suspension Lift
Just got done installing the 2" Rough Country Suspension Lift Kit on my Blazer. Overall, I am pretty impressed with the lift. However, I am thinking about adding a 2" body lift to it. So I was just wondering whether or not I will experience any major problems adding this and if anybody else has done that????
Old Jan 11, 2009 | 01:20 PM
Blazin NC's Avatar
Blazin NC is an unknown quantity at this point
Default RE: Adding 2" BL to a 2" RC Suspension Lift
Lots of people have done it, there is no major issues adding the Body Lift to your truck.
Old Jan 11, 2009 | 02:29 PM
greenjimmy's Avatar
greenjimmy is an unknown quantity at this point
what size tires are you planning on running?
Old Jan 11, 2009 | 02:34 PM
OILCOUNTRY's Avatar
OILCOUNTRY is an unknown quantity at this point
Sorry to hijack your thread but what about Body Lift on a 2DR with a manual tranny? is there any issues?
Old Jan 11, 2009 | 10:08 PM
WolfPack's Avatar
The center console has to be moved back a bit or cut...one of the two. The shifter does weird things to the console.
And yea Ive got a 2' suspension with a 2' body. Not the RC lift, but who needs fancy control arms anyway
Old Jan 24, 2009 | 08:49 AM
bammontana's Avatar
bammontana has a little shameless behavior in the past
Hello all, we are about to do add a leaf to our rear and torque up the front - after that I am thinking of installing a body kit as well.
We are throwing 31 x 10.5 tires on the truck after the suspension lift, and see if we have to trim anything incase of rubbing, but I think the body lift after that should fix that.
But to stay on topic, with the body lift, are we going to have to extend any lines such as the brake, fuel, etc. in the process?
She is a 4x4 4 door automatic.
Thanks
-Jon
Old Jan 25, 2009 | 04:25 AM
WolfPack's Avatar
Only a couple ground straps need to be extended (parts supplied with the kit), and the oil filter has to be dropped down to avoid having to extend oil lines (again, parts in kit). All the other lines have enough play or do not move. A few of the lines you do have to remove the stock bolt holding them down to free up some slack, but thats all covered in the install instructions
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
