bigger shocks with shackles and Tbar crank????
Old Sep 24, 2011 | 12:53 PM
BlazHerZR2's Avatar
BlazHerZR2 is on a distinguished road
Default bigger shocks with shackles and Tbar crank????
i have shackles and im going to be cranking my tbars do i need bigger shocks as like 2 inch lift shocks please someone tell me before i install today and im fliping my ball joints soo any imputs
Old Sep 24, 2011 | 04:39 PM
litterbug's Avatar
i did the crank and shackles and im still on my stock shocks. good luck with the shackles though. mine were a pain. soak them in partsblaster a couple days ahead if you can.
Old Sep 24, 2011 | 05:47 PM
xgiovannix12's Avatar
i have the same lift and im on stock shocks
I agree with litter bug spray them a few days before
I sprayed mine for 1 week and they came out like spreading butter on bread =P
if you have an air hammer with the pointy point you can use that to knock the bolts off
Im looking to change my shocks next year if they last intill then i was wondering what would happen if i used a bit longer ones
Old Sep 24, 2011 | 08:28 PM
mdehoogh's Avatar
I would suggest upgrading to longer shocks. I actually had to unbolt my shocks in order to install my shackles because they wouldn't allow the axle to fall down far enough (only a half inch short though)
I keep meaning to get some new ones
Old Sep 25, 2011 | 05:09 PM
AJBert's Avatar
You'll be fine. I've been running 2" shackles and the tbar crank for about 4 years now and have maxed out the flex more than a few times. The stock Bilsteins are doing just as well as when the ZR2 was new.
Old Sep 25, 2011 | 06:49 PM
BlazHerZR2's Avatar
thanks for the inputs guys yes i soaked EVERYTHING a couple days prior and then on D-day haha and while i was doing them.... nothing a HUGE snapon breaker bar, inpact gun and a snapon air hammer couldnt handle everything went as smooth as possible for bolts that havent moved in 11 years
also im getting these goodies to raise her up some more let me know what ya think
Superlift Torsion Bar Keys for S10 Blazer Sonoma (including ZR2) - Synergy Offroad
Superlift 85146 Superride Shocks for 2" Lift ZR2
anyone order off this site before???
Last edited by swartlkk; Sep 25, 2011 at 07:17 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Sep 25, 2011 | 08:06 PM
NVANZEE's Avatar
i would just try cranking the tbars up first. You might be able to get the height your looking for without buying the keys. it depends on how much the tbars are sagging though
Old Sep 25, 2011 | 10:54 PM
BlaziNator's Avatar
BlaziNator is on a distinguished road
Ditto. I use mine off-road and saw that they limited my suspension travel. I went with ProComp ES3000's on mine. Worked like a charm. Great ride and awesome price from 4wheelparts.com. If you stick to the pavement, the stock shocks should work.
Old Sep 26, 2011 | 08:49 PM
AJBert's Avatar
Great guy that runs the site, I've ordered from him many times in the past.
But, save your money. You don't need new keys or shocks. Your stock Bilsteins are more than up to the task.
Old Sep 27, 2011 | 12:27 AM
BlazHerZR2's Avatar
i ordered the stuff i cant get to my last slot on my shackles with stock shocks plus my t-bars sag a little i think they were cranked already
