biggest tires i can fit?
Old Dec 26, 2008 | 09:39 PM
thedopeshow912's Avatar
thedopeshow912 is an unknown quantity at this point
Default biggest tires i can fit?
I have a 97 blazer lt, lifted with a 2 inch body lift and 2 inch suspension..what are the biggest tires i can fit under there without havin them rub? i know 31's will fit, but will 32's fit?
And does backspacing matter? Because i have no clue what that really is...
Old Dec 26, 2008 | 10:07 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
Default RE: biggest tires i can fit?
https://blazerforum.com/m_10637/tm.htm
Old Dec 26, 2008 | 11:23 PM
WolfPack's Avatar
Yes backspacing matters. I have 2' bl, 2' shackles, and rub offroad with 30x10.50s.
Old Dec 28, 2008 | 05:14 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
I run 31's on the factory wheels without any rubbing issues. 32's would fit on mine with a little minor fender trimming.
Old Dec 28, 2008 | 08:05 PM
What are you driving, with what options, and what modifications?
Old Dec 28, 2008 | 09:01 PM
SockJock's Avatar
Sorry I should have clarified. That is on my 95 Chevy Blazer LT 4wd 4dr. My factory tbars were shot and it rode like a boat. So I went junkyard diving and found the beefiest tbars I could find on aBlazer. Yes theycome in different diameters. I got some off a 1999 or 2000 Blazer and installed them on my Blazer. The adjuster bolts are run all the way OUT. I also put a homebuilt add-a-leaf in the rear. No rubbing and no trimming. Also here's a pic showing the height of the top of the front fender lip to ground on it.
Old Dec 28, 2008 | 09:08 PM
SockJock's Avatar
Forgot to add that I had also replaced the factory rubber body mount bushings with some urethane body mount bushings. If your body mount bushings are wore outlike mine were you'll gain a little extra height by replacing them with some urethane bushings.
Old Dec 28, 2008 | 09:15 PM
Ah, ok, so not stock. Your truck looks good!
Old Dec 28, 2008 | 10:05 PM
SockJock's Avatar
Really I think you can make 31's fit with just a 2" body lift even if everything else is stock, but you need to run them on the factory wheels. If you opt for an aftermarket wheel you'll have to trim the rear of the front wheelwell openings. OH and thankyou for the compliment.
Old Feb 4, 2009 | 06:47 AM
bammontana's Avatar
bammontana has a little shameless behavior in the past
ORIGINAL: SockJock
So whats a little trimming!
I am getting ready to install my BDS 2 inch body lift (Waiting for it via UPS, the most nerve racking part)
After thats installed, I will be throwing on my 31 x 10.50 tires on aftermarket rims. Also have 1 inch adapters off the hub to mount these puppies on since their bolt pattern is 4.5 but any hoo.
If I see a little rubbing, we will trim which is no biggie. I doubt that I will have to though, we are going to do a small suspension lift with boosting up the front via the bars and add a leafs in the rear. But I will take pictures with just the body lift first to see how it looks and some measurements.
Yeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeesssss.
