-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Body Lift??? (https://blazerforum.com/forum/lifting-tech-44/body-lift-33874/)
tony991 Aug 21, 2009 03:10 PM
Body Lift???
I have a 87’ S-10 Blazer that I've been restoring... I want to put a 3" body lift on it but I’m a little hesitant because I’m kind of worried... I don’t want to rip anything out... So, When you unscrew the body mounts and jack the body up will you pull any wires, hoses, or anything??
bandidolenny Aug 21, 2009 03:15 PM
When you buy a body lift from a reputable manufacturer it will come with everything you need and a complete set of instructions. Best money I ever spent.
AJBert Aug 22, 2009 04:14 PM
Yes, you will rip stuff out when you jack up the body...
if you don't follow the instructions from a reputable kit, as already mentioned.
tony991 Aug 22, 2009 05:25 PM
well.... i was thinking of this kit.....
http://www.jcwhitney.com/autoparts/I...23030320172073
What do you guys think of that kit??
What kind of kits do you recomend??
ImScrewed92 Aug 22, 2009 09:51 PM
Looks like the kit I just got in the mail Tony, the 543 3 inch kit. Got mine on Amazon for $90 with free shipping. Came with hardware, body spacers, spacers for the vaccum shift modulator (for 4x4), clutch cable extension, steering coluom brackets, and the fuel filler extension. I've got an ASE mechanic that will do the install AND fab up bumper brackets for $200.(He did my buddies full size body lift, and he did great, and says he's done the s10 blazer before.) Is there anything not in the kit that Tony and I need to get before the installs start? Mine's a 1st gen also.
scrmmealuvsong22 Sep 1, 2009 05:11 PM
not a fan of body lifts, u see frame and it really doesnt give u more ground clearance, just room to put bigger tires on
go with a suspension lift and go big or go home
Sisk Sep 1, 2009 06:19 PM
Only thing with suspension lifts is they are extremely involved and are pretty costly. Body lift will give you a higher ride but at a pretty cheap price. I do agree with the frame showing though..it's one downside.
And you will gain more clearance with a body lift because you can fit bigger tires on. Bigger tires = more clearance because you're higher up.
AJBert Sep 1, 2009 08:50 PM
A suspension lift doesn't give you any higher ground clearance. BIGGER TIRES give you more ground clearance.
Both types of lift allow you to put bigger tires on, thus giving you better clearance. The body lift is cheaper and easier, the suspension lift offers more height.
And you can always throw sliders on to cover up the frame after a body lift.
neo71665 Sep 2, 2009 05:31 PM
Nobody makes a suspension lift worth a crap for a first gen.
ImScrewed92 Sep 7, 2009 11:02 PM
I hope Tony's project worked out. I got mine put on last weekend and it went great. Only snag was didn't have time to rig up the bumpers, but I think I can lift them myself. Spray some under coating and the frame isn't too bad, then agian I'm used to seeing as many if not more body lifts than suspensions. Yeah If you got the money, time, and resources; I'd much rather do a SFA up front and a rear spring flip kit with diffrent axles and better gears. BUT my wallet persuaded me towards the body lift for now...
