Originally Posted by kenny100034
(Post 558268)
Alright gentlemen, its been awhile I know, but my PA body lift was given to me today for Christmas, the old man finally came around, he also made the mistake of offering me up his 31's. So now for the question, I have both stock 4wd rims as well as 2wd rims with the different offset, which rims would cause the least rubbing or am i just going to either way, I believe the 4wd's will rub sway bar and frame and the 2wd's would rub more fender. Also planning on 2" shackle and 1.5" tbar crank to help clear a little bit.
Alright thank you Tibby, yeah I kinda like the wider look too
U will still rub some on the lower part of the fenders if u have a deep offset rim. I have a 2 inch body lift and 2.5 inch rough country lift with 4.5 inch offset rims and 31 inch tires and I had to mod the fenders a lot. If u do a lot of normal road driving it will be ok but if u hit a lot of bumps while turning it will rub a lot or if u offroad
I'm hoping being that I have the Z85 package like Tibby does maybe I wont rub as much, but if i have to trim my fenders a little bit that is not a huge issue, appreciate the advice and warning
Does the fan hit the lower shroud after the body lift?
Originally Posted by smaiwald
(Post 560313)
no, they come with spacers |
Originally Posted by Jamaroon
(Post 560318)
Are you sure you dont have a bad motor mount? OR a bad tranny mount?
(Post 560339)
I am ordering a body lift just wondering if there is interior stuff you need to do to get the body mount bolts out and does it mess with shifting linkage?
